  • Guests: 49
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
I hate technical spelling...
Tony Matt
Sun Apr 07 2013, 02:31AM Print
Tony Matt Registered Member #3700 Joined: Sat Feb 19 2011, 12:59PM
After reading for some time the 4HV threads, I beguin to be trouble with the proper spelling ... Anyone can advise ?
0.1 amper [A] or 0.1 Amper or 0.1 a or 0.1 coulomb per second ?
ten kilowatt [kW] or ten Kilowatts [KW] ?
one coulomb [C] or one Coulomb [C] or one ampersecond ?
half volt [V] or half Volt [V] or 0.5 v or 0.5v ?
ten meter [m] or 10M or 10 M or 10m ?
0.3 second [s] or 0.3 Second or 0.3s ?
2 microfarads or 2 Microfarads 2 MF or 2 mF ?
six kilowatthours [kWh] or six Kilowatthours ? check your electrical bill.
12 kilohertz [kHz] or 12 Kilohertz or 10 KHZ ?
What is the rule?
Cheers ]
Sun Apr 07 2013, 05:07AM
Not too complicated, but many people get it wrong.
Here's the first reference I opened out of a ton of search results: Link2
Here's a more official reference: Link2
In casual forums it's common to omit degree symbols, write u for μ, spell out ohm instead of fetching a Ω, and use ^instead of superscripting to denote "raised to the power of".
Be careful to remember the distinction between common symbols for variables (C for capacitance, I for current)
and the associated units of measurement (F for farad, A for ampere).
The SI symbol for second (the time unit, not the angle unit) is lowercase s. ms is a millisecond. mS is a millisiemens (e.g. the conductance of a 1000 ohm resistor).
Sun Apr 07 2013, 07:54AM
The SI multipliers all have a defined case. For example, m is milli but M is mega. So to avoid ambiguity you should always use the correct case: MW, kWh, kV and so on.
The SI units that were named after scientists get capital letters when abbreviated, but not when written out in full. The ones not named after scientists are lower-case always. kWh = kilowatt-hour.
When written out in full, the units are treated as ordinary nouns and the ordinary rules of spelling apply. Teslas are a unit of magnetic flux density. One tesla is equal to 10,000 gauss.
Some units have a two-letter abbreviation. If it was named after a scientist, the first letter gets capitalised. Oersted = Oe, candela = cd.
Newton Brawn
Tue Apr 09 2013, 04:03AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Hi Tony,
I just review yours theads/replies to verify your SI spelling and I have found no mistakes so far.
It appears that you post the thead just to bring attention from ours friends to provide a better spelling when typing the SI units...
Is it true ?
Regards
Newton
Tue Apr 09 2013, 09:04AM
i find reading helps alot with spelling, recently i ordered 3 very large electronics books: Art of Electronics, Power Electronics Handbook and one other that is on Inverter and Switchmode Design.
Not only do books help you learn and expand your knowlage, they really help with your spelling often!
Houdini0118
Tue Apr 09 2013, 09:17AM
Houdini0118 Registered Member #8558 Joined: Thu Dec 06 2012, 11:38PM
I find reading over what i have written helps but i rarely do that unless it is like a school paper or something.
paris
Wed Apr 10 2013, 08:57PM
paris Registered Member #3042 Joined: Wed Jul 28 2010, 12:36AM
Have no fear , spellingman is hare!!
Ash Small
Wed Apr 10 2013, 11:38PM
--Dyslexics---
-of the world-
----Untie-----
Tony Matt
Thu Apr 11 2013, 12:45AM
Hi Newton ;
You bat... Your spelling also looks good.
Steve has remembering very well, in recognation of the scientists that have contributed to the sciece, get capital letters when abbreviated, but not when written out in full.
It is fair enough.
Regards
