  • Guests: 55
Timo (40)
01/06 Ash Small (63)
01/06 Oatmeal (38)
01/08 Lyonel Baum (77)
Recommended High Pass Filter Frez for Plasma Speaker
Paul_J.
Sat Feb 23 2013, 05:33AM Print
Paul_J. Registered Member #5436 Joined: Sun Jun 24 2012, 01:44AM
Hi,
I want to add a high pass filter to the audio input of a plasma speaker. What cutoff frequency would you recommend? Meaning, what is the lowest produced frez of a plasma speaker? My arcs are roughly 2-3 inches, at high currents. The half bridge is running at 120v so I have plenty of power available
Sun Feb 24 2013, 09:49PM
I guess the question is - what is your goal?
Are you looking to have just a plasma tweeter? If so, then you can use similar cut-off frequencies used in conventional tweeters.
For general use, you don't need a high pass filter. The response of the arc itself naturally attenuates the low end anyways.
Paul_J.
Mon Feb 25 2013, 01:30AM
I'm aiming for a general purpose tweeter that goes down to a mid range, bypassing just the low bass notes.
Mon Feb 25 2013, 03:35PM
I would just use similar frequencies and roll-off thats typical of conventional tweeters.
Paul_J.
Tue Feb 26 2013, 07:08AM
Thanks, I'll implement that in my design.
Wed Feb 27 2013, 04:11PM
For my plasma speaker, I used around 70 Hz cutoff frequency (first order CR filter). Setting it lower didn't noticably increase bass, just distortion. That was for a "full range" speaker...
