  • Guests: 57
kirE (36)
Sparkie (48)
indheat lover (37)
11/22 Goodchild (34)
11/22 pauleddy (34)
11/23 Munkey (32)
TVS Diode Quick Question
ben5017
Wed Feb 06 2013, 01:28AM Print
ben5017 Registered Member #3315 Joined: Thu Oct 14 2010, 04:23PM
Can somebody explain the difference between..
Clamping Voltage:
Operating Voltage:
Beak down Voltage:
Wed Feb 06 2013, 10:24AM
Operating voltage = voltage at which hardly any current will flow
Breakdown voltage = voltage at which a bit more current will flow
Clamping voltage = voltage when a shit ton of current is flowing.
For the exact values of "hardly any", "bit more" and "shit ton" see the datasheet.
When choosing a TVS, you make the operating voltage a bit more than the actual voltage of the signal you're protecting, and you use the clamping voltage as a guide for the worst-case surge voltage your circuit will see.
ben5017
Thu Feb 07 2013, 01:37AM
thanks that clears that up.
However can you explain what signal you talking about?
Here is the context i am asking the question in.
I am building a electromagnetic accelerator. It shoots of a 24v lipo battery. My igbt's are rated for 600 volts. I expect around 200 amps of current.pulse length 2ms.
can you give me advice on sizing a bidirectional tvs diode for my application.
BTW I am trying to teach myself electronics so i apologize if this is common knowledge.
Thu Feb 07 2013, 10:27AM
Depends what circuit topology you're using and what you're expecting the TVS to do. Are you using it as a simple clamp to eat all the inductive energy left in the coil after the projectile has passed through?
ben5017
Thu Feb 07 2013, 02:12PM
Yes that is exactly what i am trying to do.
Circuit topology is as follows.
My igbt is controlled by 555 timer which is triggered by an ir emitter and detector. The 555 outputs a signal to an inverting igbt driver which then sends the signal to the igbt.
I am under the impression I want the clamping voltage as close to the rating of my igbt (600V) (as an example (x3) 180V TVS in series to get around 540V) In order to burn the leftover energy as quick as possible in order to collapse the magnetic field as quick as possible.
I am still a bit lost on what I would choose as an operating voltage.
I hope this clears things up a bit, thanks for the help man.
Thu Feb 07 2013, 03:19PM
In that case the operating voltage will be 24V, as that's what the TVS sees while the IGBT is on. This is so much lower than 600V, that you can ignore the operating voltage and choose the TVS by clamping voltage only.
The clamping voltage can be a lot higher than the operating voltage, so read the datasheet carefully unless you want to blow stuff up. smile
