  • Guests: 63
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
oxygen analyzer
Sat Jan 26 2013, 06:06PM Print
I have a Clark electrode that I will use to analyze the O2 concentration. It puts out a millivolt response to the concentration that appears to be linear. I want build a simple meter that will take the voltage (say 0 to 5v) and display a number. I remember from my college classes that there a chips that will take inputs and display numerical values. Basically, what do I need to do to accomplish this. Is there a basic circuit design that someone will point out?
Do I need a programmable chip (PIC) or can this be done with just digital technology?
Ash Small
Sat Jan 26 2013, 06:22PM
Personally, I'd hack a cheap digital voltmeter. I've seen them in discount stores for £2.95. They may be even less on Ebay, etc.
eg. £2.76 inc postage. Link2 There must be similar deals your side of the pond.
Sat Jan 26 2013, 06:56PM
The ICL7106 and 7107 were the classic digital voltmeter chips. Read the datasheets and application notes for those. If you buy a cheap digital panel meter off Ebay, it will probably have a similar chip inside, if not an outright Chinese clone.
Sat Jan 26 2013, 06:58PM
There are cheap digital voltmeter panels available via eBay, such as; Link2
I bought one that reads from 0.000 V to 3.123 V or thereabouts,
I checked it against a Fluke dmm and it's pretty accurate.
Sat Jan 26 2013, 07:05PM
I guess what I can do is use an op amp to convert a voltage that corresponds to 100% to 100 mv. I can then read the value. I think I have a digital panel somewhere in my work area.
Sat Jan 26 2013, 07:14PM
Good idea. I think the meter chips are usually 200mV full scale (to be pedantic, 199.9mV for a reading of 1999) and other ranges are achieved with an amplifier or voltage divider.
Sat Jan 26 2013, 09:22PM
Just found a digital meter in my work area. Set it to 200mv DC and it can run off of 9v. I will now set up an adjustable 3403 op amp.
I plan on making a pressure swing absorber to remove oxygen from air. I can use this to see how much oxygen is left. This is the next step for my cryogenic setup now that I've gotten the air down to -321F.
