  • Guests: 48
Ruskie
Thu Jan 24 2013, 07:17PM Print
Ruskie Registered Member #9290 Joined: Sat Jan 05 2013, 03:42PM
Fri Jan 25 2013, 12:37AM
Oh yes, good old "ASCII" (fixed pitch font) images.
A chance to propose, without starting a new thread,
a drawing style that makes schematics more compact and easier to draw.
(Anyone know of a GUI drawing program for ASCII schematics?)
Here's the original, thanks to Sam Goldwasser's Repairfaq site:
+Vcc     Q1   +----------------+
     o           |                 )::
     |       B |/ C                )::
     |  +------|    2N3055         )::
     |  |      |\ E           5 T  ):: +------|>|----------o  +HV
     |  |        |                 )::(   HV Diode, usually
     |  |       -_-                )::(    built in.
     |  |   Q2  _-_                )::(
     |  |        |                 )::( Secondary (HV) winding,
     |  |    B |/ E           5 T  )::(  intact.
     |  |  ----|    2N3055         )::(
     |  |  |   |\ C                )::(
     |  |  -----------------------+ :: +------------------o  -HV
     |  |                     2 T  )::
     |  |               |     2 T  ):: T1 - Flyback transformer from B/W or
     |  +-------------------------+         color TV or computer monitor.
     |            R1    |    R2
                  110        27   _|_
                  5 W        5 W   -
Here's the alternate, with more compactly rendered Q's and R's:
     o           |                 )::
     |           C                 )::
     |  +-------B   2N3055         )::
     |  |        E            5 T  ):: +------->|---------o  +HV
     |  |       -_-                )::(    built in.
     |  |   Q2  _-_                )::(
     |  |        E            5 T  )::(  intact.
     |  |  -----B   2N3055         )::(
     |  |  |     C                 )::(
     |  |                     2 T  )::
     +------------R1----+----R2----+
                  110        27   _|_
                  5 W        5 W   -
Comments?
By the way, I regularly encourage noobs always to put reference designators into their schematics.
Then discussions can refer to "R1" instead of "The leftmost 110 ohm resistor".
And if you ever change the component value in the schematic,
it won't break references to that location in previous discussions.
GrantX
Fri Jan 25 2013, 05:01AM
I've tried building two of these 3055 drivers (a single transistor, then the double transistors) out of boredom, and had eventual failures with both. Never had an issue with live PSU, but I was using an iron core transformer, not an ATX supply. I'm not sure if the eventual failures is related to circuit design, or the transistors used, but everything I've read about this circuit is bad.
Shrad
Fri Jan 25 2013, 08:23AM
three is a difference between old and new 2N3055 transistors
the new ones are epitaxial designs, which suffer excessively in this regime, while the old ones are rock solid (new as after year 2000 or something, don't know)
GrantX
Fri Jan 25 2013, 09:11AM
Shrad wrote ...
That's probably the issue I had, I made these drivers early last year sometime, after snatching a few 2N3055's from school. I grabbed a random bunch of both metal case and plastic package transistors from the supply closet. They all looked new, and tested good prior to using them, however it's impossible to know whether they'd been abused previously.
Ash Small
Fri Jan 25 2013, 09:38AM
Shrad wrote ...
There are also several different spec. 2N3055's, with designations like E, H and G, off the top of my head. One will work at higher frequencies (3MHz), One has higher current rating, one has higher voltage, or something like that (I'll check later and update this post). Also, there are differences between manufacturers, and even different factories owned by the same manufacturer.
I obtained half a dozen Motorolla ones from the Mexico factory in 2001, which have so far been virtually indestructible. (I blew one when running a flyback from it with no heatsink).
I started a thread somewhere about testing them to destruction, to compare the various different sources, etc. for them, but need to finish building a ~300 watt variable resistor I'm working on to use as a test load. I will then hopefully be able to ascertain which ones are most reliable.
@Ruskie: Where did you obtain yours? What make are they? and are they marked with the country of origin?
Shrad
Fri Jan 25 2013, 11:32AM
mosfet royer
Ash Small
Fri Jan 25 2013, 12:40PM
You can damp the voltage spikes with snubbers accross the 2N3055's. I think you'd need a capacitor and diode in series, with the diode connected to the collector, and capacitor connected to the emitter, with a resistor in parallel with the capacitor. I can't remember offhand what values, though.
(Maybe ~250-500uF, and at least 1kOhm, and a fast diode, maybe someone else can suggest some values?)
Fri Jan 25 2013, 01:07PM
Shrad, more like 1980 than 2000 smile
Shrad
Fri Jan 25 2013, 01:40PM
yeah I think so, I don't know why I felt 80's were a bit early for the technological change, and 90's too. I guess I was thinking about scavenging rate... by the 2000's there were not much original designs left to scavenge in generic appliance
