  • Guests: 59
kirE (36)
Sparkie (48)
indheat lover (37)
11/21 kirE (36)
11/21 Sparkie (48)
11/21 indheat lover (37)
Lets light an 1800W xenon short arc bulb
Meatball
Tue Jan 22 2013, 06:27AM Print
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
I've been scouring all over the possible results that google gives me for ICs, schematics, kits, ready made PSUs, and nothing. Most of anything I found is on youtube. I've seen two typologies so far:
Large X-former + some trigger circuit.
The guy on youtube "showed" his circuit without any explanation of it. "I've got a large transformer in that box, and this mess of hot glued coils and wires is the trigger circuit I built and now the light works"
Yeah, real helpful. Thanks for the mind bending detail.
Setup #2 I've seen is a trigger circuit + a TIG/ARC welder PSU.
This seems appealing to me since I can get a cheap 80A TIG welder from harborfreight for ~$100. Trouble is, I can't figure out a way to use any trigger circuit such that it does not interact with the TIG circuit (Which is essentially a constant current supply). I figure a rectified flyback or ignition coil could trigger the arc, but how to stop the trigger from destroying the welder?
Does anyone know if a TIG PSU would allow for manual current adjustment? It would be handy.
The bulb takes 75A @ 26.5VDC. ~20-25kV for trigger.
I've got some optics lined up, but the PSU is giving me a headache. I've got a ZVS driven flyback on hand, two 'fresh MOTs, unlimited ATX PSUs and about $150. What would you guys do?
Tue Jan 22 2013, 08:24AM
The 'start circuit' can simply be a relay that shorts across the bulb, then when it opens the inductive spike from the inductance of the transformer should be enough to start the bulb. Just keep in mind that you need a contactor that can handle the short circuit current of the supply, and opens quickly enough that the arc forms in the bulb instead of in the contactor wink Alternatively, something like a 'buzz box' for a tig welder should also do the trick.
Any tig/mig welder should have a current set knob, you need to be able to control the current depending on the material you are welding. Watch out though, most of the cheap ones are only rated for a limited duty cycle at their higher currents.
Ash Small
Tue Jan 22 2013, 08:43AM
If I understand your question correctly, any cheap buzzbox for arc welding will have a current control knob.
As for the starter circuit, you can superimpose an HV signal onto the welding current using an air core transformer, Tesla coil style.
You'll want to prevent the HV getting back into the buzzbox, but this can be achieved using a capacitor accross the buzzbox output, and maybe a choke.
This is basically how an HF TIG welder circuit works.
I used a flyback and 2N3055 for my TIG welder circuit below:
1302453905 3414 FT112240 Hf
You'll only need a pulse to start it though, but the above circuit shows how to superimpose the HV onto the output from the buzzbox. You also won't need the rectifier, unless you want DC.
Tue Jan 22 2013, 10:24AM
Yes this is how it's done, a pulse transformer which superimposes a HV spike on the output of a low voltage supply. They are often wound on a ferrite rod. The primary can also be just a few turns (maybe as few as one) and a capacitor discharges into it through a SCR or SIDACs.
Tue Jan 22 2013, 01:02PM
I've ignited discharge lamps by just waving a Tesla coil near them. Not really a production solution, though some very old HID designs did use a Tesla coil in the lamp housing, but convenient for the lab. smile
Link2 Notice "Tesla coil for ignition"
Meatball
Tue Jan 22 2013, 05:47PM
So in your circuit, your buzzbox is the rectified variac output, and the rest of the circuit is the trigger which begins with a wall wart and ends with an LC network... is that correct?
So the whole bottom portion of your circuit is the HV superimposed onto the output terminals of any TIG PSU? Just to make sure I've got this straight..
Thanks for the replies guys, I appreciate the info.
Ash Small wrote ...
Tue Jan 22 2013, 06:50PM
Just be careful -- those lamps are pressurized even when cold. If one were to burst when hot, it could shower your lab with red-hot shards of quartz.
Ash Small
Tue Jan 22 2013, 07:52PM
Meatball wrote ...
The buzzbox (arc welder) is connected to the rectifier. There is no variac. The symbol is supposed to represent a variable current transformer (buzzbox).
Then there is the choke circuit, consisting of two capacitors and HF choke. Apperently, from what others on this site have said, only one capacitor is required here. I just like 'overkill'.
The part from the wall wart to the air core transformer is the HF circuit, using the 2N3055 flyback driver circuit, and basic SGTC circuit.
The air core transformer, which in this case consists of ten turns primary and ten turns secondary, wound on an effervescent vitamin C tube (because these are made from polypropylene) superimposes the HF HV onto the welding current (the secondary is the welder cable itself).
This circuit converts an arc welding buzzbox into an HF DC TIG welder.
What you will need is a cheap arc welding buzzbox (you mentioned an 80 amp one), and a means of supplying an HV pulse. If you use a ferrite rod instead of the air core transformer I used, just wind the welder cable around it to form the secondary, and the primary will be from the pulse transformer, or capacitor and SCR, or whatever you decide to use (you could use a flyback or ignition coil, I expect).
(I don't think an air core transformer would work with just one pulse, due to the 'loose' coupling)
I'd advise putting a capacitor accross the output from your buzzbox, to keep the HV pulse out of the buzzbox. There is probably no need for the choke and second capacitor.
EDIT: Some adverts describe arc welder buzzboxes as being suitable for TIG welding. You can use them for 'scratch start' Tig Welding, but this contaminates the workpiece with tungsten. (unless you clamp a piece of scrap to the workpiece, and scratch start on that, but as you end up welding it onto the workpiece you then have to grind it off. Scratch start TIG welding using this method is only used on long distance gas pipelines as far as I'm aware, to eliminate the possibility of stray HF HV causing an explosion elsewhere in the pipeline)
Meatball
Wed Jan 23 2013, 02:16AM
Ash Small wrote ...
Ah ok. So I'll need some beefy 150A diodes for the rectifier (probably have to heatsink/cool these), a choke with large gauge wire to handle the current, a capacitor with around 3X the breakdown voltage as the HV trigger arc, I'll need a fairly large ferrite core (do you recommend cylindrical? Or a closed square?) to wind a simple SGTC driven by a rectified flyback. The 3055n circuit self resonates and the ferrite TC is basically an isolation transformer.
The cap across the buzzbox with have to have a HV breakdown rating also yes? The larger the capacitance the better? Something on the order of uF then?
I've found this arc welder: Link2
It says 100% duty cycle is ok, and for up to 100A I can't go wrong, right?
Oh, and as for the bulb, I plan on keeping it well contained and away from me while its connected.
I've been around some unbelievable laser beams (YAG, eximer) and tesla coils (DRSSTCs), but for some reason I am actually afraid of this project most. I feel it is the most dangerous I've ever attempted.
75A @ 26V is nothing to just mess around with.
Thanks for your advice so far, you are very helpful.
-Tyler
Ash Small
Wed Jan 23 2013, 09:01AM
Meatball wrote ...
-Tyler
The welding transformer (buzzbox) you linked to is ideal.
You won't need a rectifier. AC should be fine for your requirements.
Also, the general consensus on this forum is that you won't need the choke , just one capacitor accross the output of the buzzbox.
The ferrite rod from an old AM/FM radio should be ideal as a core for superimposing the HV pulse onto the output from the welder.
You also won't need the SGTC circuit, as all you need is a single pulse to start (ignite) the bulb. (At least, I don't think you'll need to re-ignite the bulb every half cycle-others here will be able to clarify this point for you).
As Dr DC suggested above, all you will need is a single pulse from a capacitor, switched by an SCR, for example. (You could also use a single pulse from an automotive ignition coil or flyback transformer, I think. You would basically just need a switch and small 9V battery (PP3, for example) for this).
I'd wait until someone else confirms what I've said though, just to be sure.
