  • Guests: 27
kirE (36)
Sparkie (48)
indheat lover (37)
11/21 kirE (36)
11/21 Sparkie (48)
11/21 indheat lover (37)
Buck converter IC
Alex M
Mon Feb 04 2013, 06:37AM Print
Hi,
Can anyone recommend some buck converter controller IC's? Its just like any electronic component there are lots of them to choose from, I am just looking for one to build my first buck converter.
Supply voltage will be around 12v (gel cell) and the final voltage needs to be around 6-8v at about 2 amps. One with some kind of built in current sensing or feedback loop is what I am looking for.
Thanks!
Dr. Slack
Mon Feb 04 2013, 08:08AM
I recommend you start of at maxim-ic.com.
a) they do a lot of products
b) especially in that sort of range
c) they have a parameteric search tool, app notes, tutorials and data sheets to help you choose the part and design the other passives round it
d) and when you're done choosing, they have a policy of providing samples to individuals, no questions asked
And no, I don't have shares in the company, but I do have a number of their samples in various projects.
Carbon_Rod
Mon Feb 04 2013, 08:50AM
LM5118
A Buck-Boost chip that covers most battery related applications...
smile
macona
Mon Feb 04 2013, 02:17PM
macona Registered Member #3272 Joined: Mon Oct 04 2010, 11:40PM
Alex1M6 wrote ...
Hi,
Thanks!
The LM2676 is pretty popular. It runs down to 8v input and 3 amps out:
Mon Feb 04 2013, 02:31PM
I can recommend the Simple Switchers, I've used the LM2576 quite a lot and it just works.
Alex M
Mon Feb 04 2013, 03:28PM
Thanks for all the replies guys! This is just what I was looking for.
Will be ordering some IC's very soon.
2Spoons
Mon Feb 04 2013, 09:05PM
ti.com webbench utility.
Stick in your power and voltage requirements and it picks out a bunch chips for you. You can optimize selection based on cost, footprint and efficiency.
Pick a chip and you can run sims, re-optimise, and even get a complete BOM with part numbers!
