  • Guests: 52
stacking coils together
1 2 3 4  last
Tue Jan 08 2013, 11:12PM Print
Andre Registered Member #6921 Joined: Wed Sept 26 2012, 07:47PM
I'm trying to stack 2 20Kv coils into one ferrite core but when I connected them together it adds up to 10KV but by itself they can produce 20KV what am I doing wrong?
Clipboard02
Ash Small
Wed Jan 09 2013, 12:35AM
Maybe connect the coils (secondaries) in series, then 'double up' (series) the diodes in one rectifier?... (assuming the diodes are only rated for 20kV)
(hope that makes sense)
Wed Jan 09 2013, 01:13AM
1357693752 543 FT148771 Twin Secondary Doubler
Perhaps you could add them like this. (ignore the centre taps on the windings)
Wed Jan 09 2013, 01:40AM
Proud Mary : it seems the picture you posted is the same as I did the only difference you put 2 caps.
Ash Small: I did that and is worst, it would not go over 5KV
I was wondering if anyone ever did something like this? :(
Wed Jan 09 2013, 02:15AM
Andre wrote ...
It won't work properly without them.
Shrad
Wed Jan 09 2013, 08:28AM
it seems like a phasing issue
Wed Jan 09 2013, 03:16PM
Proud Mary : didnt make much difference it went up to 11kV
Shrad: I though that too, so I switch the direction of one of the secondaries, and it only went up to 13KV.
I can not be the only person who ever try this :) who has done it successfully ? :)
Ash Small
Wed Jan 09 2013, 03:19PM
Maybe more resistance would help?
Maybe the voltage is 'sagging', due to the current being drawn?
(doubling the number of turns doubles the voltage, but halves the available current, while the voltage is trying to push twice the current through the resistors (I=V/R))
Wed Jan 09 2013, 03:26PM
Ash Small wrote ...
I dont undertstand what you mean,
I will think the core is saturating, but why is stoping at 10KV while each coil can produce 20KV by itself?
this is a picture of it:
0029
Wed Jan 09 2013, 03:45PM
Are the two windings in phase? What happens if you reverse the connection to one of them (attention: fuses!)
1 2 3 4  last
