  • Guests: 55
Christmas lights in series as HV load/ballast
Fri Dec 28 2012, 09:14PM Print
Remember when Christmas light strings exclusively used C7 or C9 lamps, screwed into parallel-wired sockets? Each lamp about 3 watts (sometimes 5), at 120 or 130 V in USA.
A parallel light string can be converted to series by cutting one wire in each segment between sockets. So a string of 25 3-W lamps could become a 25 mA load for 3000 volt power supply, etc.
Time to try this, since I took advantage of seasonal-merchandise closeout sales.
Am looking forward to using lights instead of big tubular resistors, as switchable loads to characterize some HV transformers.
Caveat: In a high-voltage series string, if one lamp filament burns out it will probably arc and could start a fire. I am told that in early 20th century electric streetcars, on a 600 volt grid, cabin lighting used strings of five 120-V lamps. Vacuum-filled lamps, generally obsolete even then, were used to prevent the arc problem.
So the lamps should be arranged and supported so operator can easily keep an eye on the whole array, and should not be left unattended while on. I did this many years ago for Christmas decorating. Wired twenty medium-base sockets in series, loaded them with 25-W colored party bulbs, and ran the string from a microwave oven transformer. Never had any trouble with thermal runaway in the fastest-heating lamps, when the string was switched on.
1356729286 2099 FT0 Party Colors
Sat Dec 29 2012, 03:27AM
My Christmas lights are all led
as searching for the blown bulbs in series strings drives me nuts.
Some indicator filament lamps are still 'vacuum filled'
many filament lamps use low pressure inert gas that can arc.
Filament lamps make good PTC ballsts,
and the low resistance when cold/starting sort of simulates a capacitive startup load.
Ash Small
Sat Dec 29 2012, 11:38AM
Ours aren't LED, but are wired in series.
I seem to remember when I was a kid, that the first bulb in the string was a fused link, or something. I(f they didn't work, you just replaced the first bulb, so they must have been wired in series too.
I think some were wired in parallel though, because I remember some bulbs not working in one string, I think.
Tue Jan 15 2013, 07:18PM
Here the bulbs are almost always in series, but if one burns out the rest still works, because they contain a device (most likely a NTC or TVS) which still passes current after the bulb burns out.
Harry
Tue Jan 15 2013, 08:04PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
My physics textbook says they're wired in series but designed to short when they fail so it can still conduct electricity.
Sulaiman are there really ones that arc when blown? I thought that would get far too hot, surely?
