  • Guests: 52
whats inside a FBT......this
paris
Thu Jan 03 2013, 01:15AM Print
paris Registered Member #3042 Joined: Wed Jul 28 2010, 12:36AM
Hi, I opened up an ave size TV FBT and hacked into it with a hammer and punch/chisel , eventually finding grey resin around the sec and pri coils.
The white ceramic is a job to get thru.
removed pri because thats nothing interesting and then I was left with sec.
I had to use dremel to grind out centre and fret saw to cut thru grey resin.
the coil is protected by layers of clear poly whatsit,both on the outside and centre.
the remaining coil =
24mm od
20mm id
28mm tall
21mm actual coil height
this was just an exercise to see whats in FBT. I have no idea what size wire that is buts its small. The smallest wire Ive seen is on a comp hard drive , theres super fine wire on the moving arm that travels across the disc.
1357175756 3042 FT0 Bg 006
GrantX
Fri Jan 04 2013, 04:06AM
Interesting. Any idea of the number of turns, or at least the number of layers and a rough estimate of the turns on each layer?
I had always thought that the secondary of a modern flyback was wound as several split coils connected in series via diodes. Did you find any diodes or caps inside the epoxy?
paris
Fri Jan 04 2013, 07:00AM
yea there was debri flying everywhere, I dont recommend doing it just know that it can be done.
Ive seen x ray of a marx gen some where on this site but havent seen 1 of a FBT, maybe the ceramic is too dense Id say.
The wire is finer than ignition coil wire ,its like silk. dont ask how HV gets to output lead because I didnt see , too busy chippen...
inside dia of coil is 20.3 or so and between each layer theres the clear plastic sheets . I wrote the dimensions hoping some one could estimate ...how many layers fit in 1.7 mm??
its hard to say, my next mad idea would be to find out ;)
all diagrams Ive seen have diodes etc I was thinking maybe the ceramic has silicon closest to the sec. large FBT have clearly cap and diode showing in the shape of their casing.
on the tuning side with the pots theres a ceramic sheet with the tracking for the pots.
everything is definitely HV heavy duty.
it would be a task to rewind onto another former . Im wondering who sells this wire.
the winding machine must be impressive to see.
I just thought it would be interesting sight to see a naked secondary coil
paris
Fri Jan 04 2013, 11:45PM
heres ignition coil wire .090mm = BS 39 = SWG 43 = 3.531 mils
1357343149 3042 FT148595 Ign Wire
paris
Fri Jan 04 2013, 11:53PM
heres the FBT wire = .035 mm = .001378" dia . what size that is I dont know but will try to find out .
the plastic sheets are .074 mm thick
the centre pretty much fell out ... after I wrenched it!
21mm / .035 = 600 turns per layer ,thats only approx
1357343580 3042 FT148595 H 005
1357343580 3042 FT148595 Fbt Wire
Ash Small
Sat Jan 05 2013, 01:46PM
0.04mm is about the smallest diameter used by coil winding machines (generally).
I worked in a coil winding factory for a bit, and they said their machines had trouble winding 0.04mm dia., and it kept snapping.
paris
Sat Jan 05 2013, 07:21PM
I would say your right , hard to measure this stuff so Im probably crushing it when I measure.
What size is this stuff called????
I cant find anything that small on AWG gauge etc
the winding machine must be so delicate , but imagine how many of these coils were made thru the years, the rejects bin must be huge.
Sat Jan 05 2013, 08:13PM
Solderable polyester enameled round copper wire diameter 0.03 mm is available in metric tonnes from Beijing Tianyulonghua Trade Co., China.
Sun Jan 13 2013, 05:35AM
there may not be a AWG equivelent... but still nice work, i did the same destructive analysis back in high school in 1998...
not only are these difficult to wind, but you dont even have to break the strand, just stretch it to the point micro-scopic striations appear in the insulation, then your boned.
Dragon64
Mon Jan 14 2013, 05:36PM
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
If the flyback you dissected was a DST, I would love to see the internal diodes if it managed to survive being chipped away from the epoxy. :)
The above patent image is the best representation of what it would truly looks like without the epoxy.
