  • Guests: 78
OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
01/25 Patrick (44)
Single wire power transfer...
Tue Dec 18 2012, 02:58AM Print
Is it possible to send 4 to 5 volts at 100ma through a single conductor?
i remember the simple diode radios that were effectivly self powered from the rectified radio wave, i made as a child. So i was wondering if it would be possible to send AC at 10-100kHz through a rotating metal shaft then rectify it and smooth it with a cap? or am i crazy?
the power is to be used for a small MCU/PIC and laser...
Tue Dec 18 2012, 04:15AM
It would be possible, although I do not thing that having a 1/2watt of RF power radiating through your drone will be the best idea. You would also need some sort of ground plane to couple power through (presumably the frames of the drone and transmitter would work for that).
Could you use a rotating transformer? If you can find one, VCR's have nice rotating transformers in the read heads and good bearings, there are also plenty of channels so you could send data back down as well if necessary.
Josh Campbell
Tue Dec 18 2012, 05:11AM
Josh Campbell Registered Member #5258 Joined: Sun Jun 10 2012, 10:15PM
Sounds like you need to brains storm on other methods of power transfer to a rotating head. Does any data need to flow to or from the rotating laser, or just power to it?
Gogo gadget brain storm: (note brainstorm may contain spurious idiotic ideas)
-A triangle of rotating solar panels receiving light from internal source(s), smoothed with a cap. Would need to series a few small panels to reach 5V or use a simple boost converter.
-Circular traces on a base circuit board. Soft tabs (metal type... not sure) protruding from rotating head that drag on the traces.
-A stationary neodymium magnet and one or more coils that pass by the magnet, smoothed and boosted as needed. (Very feasible, just like the shaky shaky flashlights.)
-A zero-point module on the rotating head. (My favorite so far.)
-Ground the motor shaft, this provides ground reference to the rotating circuit. Have a piece of spring metal that hits a post as it rotates, this post has a voltage of your choice on it. Smooth, boost, etc.
-Put small generator on the rotating head with a rubber wheel that rolls on some surface. You know the rest.
-Install a gerbil wheel in the rotating head, let the gerbil sit in the pilot's seat. Watch as you're creation flies without LIDAR because the gerbil wheel is a dumb idea but the gerbil in the cockpit was a good one.
-Scrap a DC motor brush assembly, mount on the top if mounting below is impractical due to the already spinning motor.
-Something with magnets... I think that is the key if you don't want touching metal parts.
-A small windmill on the rotating head.
-A small rechargeable battery on the rotating head, a couple miniature li-po's maybe. Charge when stationary. Not ideal but easy to implement.
-Place a pelter heat junction vertically on the rotating head with a heatsink on one side, paint the other side black. The fins run horizontally so the wind will blow over them as the head turns. Pulse a high power laser at timed intervals to only hit the black side. Each junction only putouts about a volt at a respectable current, so stack 5.
-PIEZOELECTRIC ENERGY HARVESTER
I'm done. :)
Tue Dec 18 2012, 05:59AM
2bytes wrote ...
only communists use Gerbils in scientific experiments, in the west, we more properly use hamsters. like civilised people. this is the best idea yet, a hamster powering and flying my drone, no SLAM model needed! just peanut butter! cheesey
EDIT: on a more serious note, the VCR idea has me intrigued.
Mattski
Tue Dec 18 2012, 07:16AM
You recall the recent thread on single wire power transfer? Link2 It can be done, but you need a capacitive return path for the current . If you transmit at high enough frequencies where you can get good radiative power transfer then you don't need a return path, but radiative wireless power is not a particularly simple or economical approach. There would also be regulator issues there.
Andy
Tue Dec 18 2012, 07:20AM
You might be able to use rfid type setup
Ash Small
Tue Dec 18 2012, 12:37PM
I'd look into a rotating coil/coils, with fixed magnets, although the idea of having a hamster pilot a quad-copter powered by a Tesla coil does sound intriguing.
Tue Dec 18 2012, 01:29PM
You might look at some army surplus outlets for guided missile control wire, which comes in spools. It contains a mix of insulated conductors and steel wire and is very fine but strong. I believe it was used in Semi-Automatic Command to Line-Of-Sight wire-guided anti-tank missiles like MILAN, and more recently, BGM-71 TOW.
Tue Dec 18 2012, 05:33PM
I may just use carbon brushes for power and 433MHz wireless for sgnal. and for the initial prototype ill use zinc-air batteries.
Electra
Wed Dec 19 2012, 12:18AM
Couldn’t you use a movable mirror rather than rotate the whole assembly,
Some old types of barcode scanners used a rotating hexagon mirror for scanning.
If you have to rotate the electronics to get 360 coverage, but the speed isn’t so high then yes mechanical slip rings would be simplest for power.
It might be possible to do some king of rotating optical link for data, along the axis of rotation if you have space above it.
As for rotating inductive transformers you might need you use some kind of modulation for binary data signals.
