  • Guests: 78
OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
01/25 Patrick (44)
bus bar materials / source / construction
lightlinked
Thu Dec 20 2012, 01:21AM Print
lightlinked Registered Member #2087 Joined: Tue Apr 21 2009, 08:32AM
what are custom bus bars made of? I'm looking at some C110 copper flat bar Link2 is this appropriate for machining into bus bars for inverters and what not? I also have some .125 silicone bronze sheet. would that work just as well?
What about connecting bars together? Is it better to mechanically fasten them or is it okay to braze them together with brass or silver solder?
Shrad
Thu Dec 20 2012, 07:39AM
flattened coper tube is perfect for that
brazing as well as bolting is nice enough, but when bolting you must carefully clean the bars at the contact surface, and maybe even put a small cleaned lead foil between them so pressure fills the tiny gaps and maximises contact surface
Ash Small
Thu Dec 20 2012, 07:50AM
Firstly, there are several different types of 'silicon bronze': Link2
This one seems to be used for current carrying applications: Link2
Table 2 in this link gives the relative electrical resistance for various coppers and silicon bronzes: Link2
and illustrates that the resistance of silicon bronze is ~5-10 times greater than copper.
lightlinked
Fri Dec 21 2012, 12:30AM
i guess that rules out the bronze. the C110 is full hard so would i have to anneal it before making bends?
Fri Dec 21 2012, 07:41PM
Brazing will be fine for connecting copper busbars. As will soft solder, unless you intend for the bars to operate so hot that the solder would melt.
lightlinked wrote ...
Why does 5x or 10x greater resistivity rule out the bronze? Have you made any design calculations of busbar electrical and thermal resistance, and voltage drop or heating at your intended current? If 0.025 Cu would be low enough resistance, then so would your 0.125 bronze. Or 0.050 aluminum?
[edit] The silicon bronze alloy Ash pointed out has electrical conductivity of 38% IACS, so if you're lucky, the stuff you have is plenty conductive. Do you want advice on how to measure it?
Wrought copper gets work-hardened as it's rolled down at the mill. Buy enough extra to make a test bend before you bother with heat treatment. Red-hot is plenty hot to anneal copper. Then OK to quench it in water. I don't know if quenching actually leaves it softer, but it sure won't make it any harder than air cooling.
Here is one site with pictures of formed copper busbars. Link2 See also their laminated busbars.
Here is one about DIY tin plating to keep the busbars looking good. Link2
[edit] The products I design contain many busbars fabricated from 0.050 to 0.125 thick copper sheet, all with bends, all tin plated, and mostly insulated from bars at different voltage by 0.010-thick FR-4 sheet parts. I could find out the material spec if you want.
Ash Small
Fri Dec 21 2012, 11:14PM
klugesmith wrote ...
Air cooling is fine, from what I remember when using copper head gaskets. It is plenty pliable after. It age hardens, from what I remember, as well as work hardening.
