  • Guests: 82
My first spark
1 2 3 4
Andy
Mon Dec 03 2012, 09:25PM Print
Just got my first spark ,seeing what a 15kv nst can do. Its spaced 1cm apart I thought i'll need 30kv..
1354569942 4266 FT0 Firstspark
Mon Dec 03 2012, 10:04PM
Yay! smile
The 30kV/cm rule is a theoretical limit, it doesn't hold for electrodes with sharp points or uneven surfaces.
Also, a NST can make more than its rated voltage during the transient at switch-on.
dex
Tue Dec 04 2012, 10:14AM
dex Registered Member #2566 Joined: Wed Dec 23 2009, 05:52PM
try "needle-plane" gap.with 15 kV nst (21.2 kV AC voltage peak) arcing over 1.5-2 cm gap is possible.
Tue Dec 04 2012, 11:53AM
Steve Conner wrote ...
I determined by experiment that a Tunewell 5 kV - 0 - 5 kV 30mA NST developed 14 kV across its unloaded secondary, which only fell to the nominal 10 kV when 8 mA was drawn.
Tue Dec 04 2012, 12:56PM
Peak or RMS? tongue
Tue Dec 04 2012, 01:36PM
Peak or RMS? tongue
Just for you, Steve, I will re-measure the unloaded secondary output with an electrostatic RMS voltmeter this evening, and report back accordingly.
Tue Dec 04 2012, 10:17PM
Proud Mary wrote ...
when i was engineering my HV probes, i measured my own 12kv 33ma NST and it measured supprisingly high(unloaded), there are scope pics somewhere here on the forum...
Ash Small
Tue Dec 04 2012, 11:29PM
This fact is well known in the fusor community, etc,
NST's are used to ignite plasmas, much the same as arc welders. They are designed to have a high open circuit voltage.
GrantX
Wed Dec 05 2012, 01:40AM
Congrats on finding a nice NST! They're getting harder to find every year. What make/model is your one? From the looks of the arc it's a 30ma NST?
I've had a 15kV/60mA NST for over 2 years now and it's been great. Very versatile and handy when you need some serious potential in a pinch. I also have a 6kV/30mA and a 12kV/60mA unit sitting around. The 6kV transformer is currently powering (for the first time ever!) a smiley face neon sign in my workshop, since it's dodgy ebay high frequency unit crapped out after 20 mins of runtime :p Iron all the way!
Andy
Wed Dec 05 2012, 02:08AM
yep 30ma ene245-15030 daehan, plan on use it for this, should be fun :)
1354673330 4266 FT147459 Marxsetup
