  • Guests: 70
TL494 flyback driver low output
cjanik
Thu Nov 29 2012, 02:22AM Print
cjanik Registered Member #4460 Joined: Sat Apr 07 2012, 08:31AM
I built the flyback driver according to this schematic:
It was working great until I was running it really hard and I forgot to turn on the fan I was using for cooling. Anyway a few of the mosfets failed spectacularly and I replaced them. I fired it up again and the output was barely what you would get from a 2n3055 driver, not the fat white arcs I was getting before. I hooked it up to the scope and I noticed that the waveform didn't have the initial oscillation at every peak like it used to they, were looking really square. I replaced the tl494 and the tc4429 and still get the same results. Do I need to change all the mosfets at once? What else might be wrong with this thing? I'd appreciate any help!
mladanada
Tue Dec 11 2012, 08:30AM
mladanada Registered Member #7321 Joined: Wed Oct 17 2012, 11:27AM
Can you post a picture of the waveforms at the 4429 output?
