  • Guests: 32
Fading 32 Led's with 555 timer's
Chip Fixes
Fri Nov 30 2012, 12:31AM Print
I was wondering if it would be possible to fade 32 Led's using one or two 555 timers? The circuits I have come across are not able to fade more than five
BigBad
Fri Nov 30 2012, 03:12AM
Try an arduino instead
Mattski
Fri Nov 30 2012, 03:43AM
I'm guessing that you're doing something like putting the LEDs on the timing capacitor in a 555 circuit which has a sawtooth-like waveform, and the LEDs are drawing too much current past 5 LEDs or so and the capacitor isn't charging. Decreasing the charging resistor value should allow some increase in the # of LEDs, but a more extendable method would be to just buffer that voltage with an opamp voltage follower or another type of buffer circuit so that the LEDs don't affect the 555.
Fri Nov 30 2012, 05:21AM
i presume hes not power the leds throught 555? he should be using a pass transistor for power, the 555 for signal, thus the number of LEDs wont matter, so long as you keep up with the power transistors.
Chip Fixes
Fri Nov 30 2012, 05:35AM
Ah yes, I was using a transistor but I couldn't get the LEDs to fade. They either constantly stay on or won't turn on at all. I think it's just a silly error on my part, I was going to troubleshoot it tomorrow.
Fri Nov 30 2012, 06:12AM
ive blundered the 2 R's a C in the RC timing circuits attacthed to the 555, your power transistor is running off pin3 right?
Carbon_Rod
Fri Nov 30 2012, 06:14AM
The PCA9685 i2c chips can set 16 synched or staggered PWM outputs for LEDs.
In theory, the address space for these supports 64 chips.
Fri Nov 30 2012, 08:10AM
My answer to the original question is, Yes.
The fading I assume is achieved by pwm using the 555 in astable mode.
e.g. LM555 @ 15Vdc supply, load (leds+resistors) between +Vcc and pin3
Datasheet Values ..ON output = 12.5V @ 200 mA = 2.5W
e.g. red led @ 20mA = 1v8 approx. ... 4 series led = 7v2
... resistor=(12v5-7v2)/20mA = 5.3/0.02 = 265 R .. use 270 R
8 parallel sets of (four series led with resistor) = 8x 20mA = 160 mA = well within spec.
and 4 x 8 = 32 leds. (plus 8 resistors)
on the other hand, 32x 3W led would need a power transistor between load and 555 pin3
if using a power transistor, other drive options are available
e.g. switched constant-current (or voltage) from the higher un-regulated dc supply.
...etc.
Chip Fixes
Fri Nov 30 2012, 04:38PM
Yeah I'm trying to go the transistor route because I want to use a 5v usb port as my source voltage. The LEDs are rated for 2v at 10ma so I have 16 groups of 2 LEDs (The LEDs in each group are in series). With each group in series with a 33ohm resistor that is connected to the emitter pin of the transistor. Pin 3 from the 555 timer is wired to the base pin of the transistor through a 33k resistor and of course the collector pin of the transistor is connected to my source voltage. But for some reason my transistor is only oscillating between 1 and 2.5v. There's a 2.5v drop through the transistor and I don't know why.
Shrad
Fri Nov 30 2012, 05:44PM
LT8000 from linear might be a nice bet for this
