  • Guests: 56
01/12 RoV IW3IPD (63)
Need some help
Platinum
Fri Nov 23 2012, 12:15AM Print
I made a flyback driver a while back with an old cheapy ATX PSU, that was around 380W~ (12v x 32a), and with other ferrite cored SMPS's. While this gave pretty powerful flyback arcs they would not last more than 5 minutes, the problem was HV coming back into the powersupply, how do I stop this from hapening, then if I'm correct this will be a good way to power a flyback for HV.
To power the flyback you directly solder wires on the secondary part of the transformer inside the PSU, this is unrectified, unregulated HFAC. I assume.
Ash Small
Fri Nov 23 2012, 12:29AM
EDIT: This post is incorrect. I've posted again further down the thread,
(Hi Platinum, my guess is that you need to put a resistor in series with the arc. I don't think it's a problem of HV getting back into the power supply, but more a problem created by by-passing the the regulator circuitry in the power supply, and drawing too much current.
This is fine for a couple of minutes, until the 'fets (or whatever) overheat.
This is just a guess though, others may have other suggestions.)
Platinum
Fri Nov 23 2012, 12:51AM
In series with the arc? What resistor should I use? I'm not sure if I even have some resistors anymore.
Tony Matt
Fri Nov 23 2012, 04:55AM
Tony Matt Registered Member #3700 Joined: Sat Feb 19 2011, 12:59PM
Hi Platinun !
I believe if you give more details you can have precise information about your trouble and get the right solution.
Why you do not post a sketh a complete schematic of your SMPS as well as the flyback drive ? A material data also is required.
Cheers
GrantX
Fri Nov 23 2012, 07:39AM
Would this be similar to powering a flyback off the HF output of a low voltage halogen PSU? I tried this when I removed an old HF halogen transformer from the ceiling, but at 24VA input I didn't get anything but the faintest spark from a variety of flybacks. Even when I held both the output lead and ground in my hand I couldn't feel any current flow. I guess it was putting out about 1000v at a few uA.
Ash Small
Fri Nov 23 2012, 10:45AM
Platinum wrote ...
Hang on....I should remember not to post after drinking.
There are two issues here, I think. If you add a resistor to restrict current from the power supply, place it in series with the primary of the flyback. I assume you are by-passing the regulator circuit in the power supply.
The other issue could be voltage spikes from the flyback primary getting back to the secondary of the PSU, causing voltage spikes in the primary of the PSU and driver circuit.
You'll need a 'scope to check for voltage spikes in the primary circuit of the PSU, but you can check the current in the flyback primary with an ammeter.
If it is voltage spikes a snubber circuit should sort it out, if it's drawing too much current a resistor in series with the flyback primary should sort it out.
Sorry about the confusion,it was late last night when I posted.
Platinum
Sat Nov 24 2012, 12:20AM
I think I'm going to buy two GF 250Watt 12v halogen PS (and series the outputs) and go very easy on the primary turns on the flyback. I'm unsure what type of circuit these halogen PS's use but in the 100watt you have two 13009 transistor if I remember correctly andf the 250watt has 4 of them. The circuit is infact simple.
I've probably already asked this but is there any weird way to get HV arcs? Except CFL, do all laptop's have CCFL inverters? Would I be able to make an arc with this, or could I buy something cheap-ish (£30~) to make some arcs? (I will also buy halogen supply) I have flybacks and ignition coils..
GrantX
Sat Nov 24 2012, 04:35AM
Let me know if you have any success with those halogen drivers, I was never able to get any decent output. IIRC the output of the halogen PSUs need a resistor in series with the primary of the flyback, and they will also need either a high power resistor or a halogen lamp across the 12V output to provide a stable load, otherwise you may damage the power supply.
EDIT: Mikes Electric Stuff on youtube has a demonstration of a halogen power supply being used to drive a flyback: youtube link
Platinum
Sat Nov 24 2012, 12:08PM
XravenorX wrote ...
I have had success with them before. But I always used to use like 3 turns on the flyback's primary as I was stupid, use atleast 6. Even then I think it'll run for a limited period of time, so I'd use 10-15. To have a better output you could always series two transformers.
This thread maybe able to show you something...
Also this website sells high power halogen power supplies, as well as the domestic 250watt ones (It seems that 250w is the highest you can buy, but this website sells alot more high power ones)
Mon Nov 26 2012, 12:03PM
Can you really connect those halogen transformers in series? The outputs are high frequency AC, what's to guarantee that they'll be in phase?
