  • Guests: 37
Dave Marshall (41)
Worms (47)
11/08 Bert (78)
11/08 MRacerxdl (34)
11/08 Alebaba (33)
Circuit Simulator
ZakWolf
Wed Nov 21 2012, 06:21PM Print
In my engineering class we are using a circuit simulator called Multisim. I had drawn up my own circuit for a pcb of a half bridge plasma speaker using the sg3525. I had asked on here a long time ago to help debug my circuit, after extensive testing and no results I gave up. I figured I would input my old design in the simulator to see if everything works.
One problem, I cannot find an sg3525 model or an equivalent anywhere, I was wondering if anyone had previous experience with multisim and could make a spice model of the IC for me.
Thu Nov 22 2012, 06:13AM
see if the model is SG2525 or UC2525,UC3525
Experimentonomen
Thu Nov 22 2012, 04:23PM
SG2525 is totem pole output while SG3525 like the TL494 is open collector output.
I have a TL494 model for linear tech's Switchercad if thats of any help.
ZakWolf
Fri Nov 23 2012, 07:05AM
I will check for those ics Sulaiman
Meatball
Mon Nov 26 2012, 07:56PM
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
You may have to build your own device if it comes down to it. Multisim is a SPICE simulator, so there may be device description code available from the manufacturer.
ZakWolf
Mon Nov 26 2012, 11:49PM
I checked for the alternative chips, i couldn't find them. I messed with the "model maker" and it was a bit confusing. I will work on it
