  • Guests: 38
Linear induction motors?
BigBad
Wed Nov 28 2012, 06:46AM Print
I'm thinking about building a couple of linear induction motors, not sure the best way to do it.
I was trying to work out what the best thing for the backing plate is, but then I realised I could probably just use ferrite cores (u-cores or e-cores) and just lay them out appropriately and then lay the coils on it, and then pot the whole lot together.
I need a reasonable amount of power (like a couple of hundred watts mechanical would be good), and running at up to (say) 20 m/s.
Has anyone done anything like this before? Are there any tricks or pitfalls?
I'm mainly going to use it for pushing stuff, not maglev, although I may do that for fun, and the aluminium strip I want to accelerate is about 3cm across and 3mm thick, so square pole sizes of about 3cm would presumably be good?
BigBad
Wed Nov 28 2012, 11:35PM
I found that there's been a recent youtube upload of Laithwaite at his peak, (before he had his gyroscope madness), check it out, it's pretty cool:
