  • Guests: 71
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
Scaling up Marko's wireless power demonstrator?
hsieh
Tue Nov 20 2012, 02:51PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I am planning to make a wireless power demonstrator for my school project.I had built Marko's wireless power demonstrator before.But this time I want to transmit at least 100W of power.Can I just scale up Marko's wireless power demonstrator?As far as I know,its similar to the Royer oscillator/Mazzilli ZVS driver.And I have seen people building 1KW or more powerful Royer oscillator based induction heaters.
My circuit now can transmit about 10W. My resonant frequency is about 600KHz. My MOSFET(47N08) get hot fast,how can I fix this problem?Can I put an inductor in serial with my transmit/receive coil to lower the resonant frequency and reduce switching loss?
Thnaks
1353422990 1412 FT0 P1000264
Tue Nov 20 2012, 07:50PM
Have you taken a look at the voltage / current waveforms through your switching devices to see whats going on?
Tue Nov 20 2012, 10:53PM
Yes, I second that. It seems that MOSFETs can sometimes be too slow and spend time in the linear (resistive) region rather than hard switching causing heating.
A simple 'scope check should show this, but watch out for excess voltage..
hsieh
Wed Nov 21 2012, 11:51AM
I scope the gate voltage and found it look like a sawtooth wave.Should I decrease the value of my gate pull up resistor (100ohm)?What value should I try?
Edit:photo added
Vgs
1353499191 1412 FT1630 Imag0507
Storken
Wed Nov 21 2012, 04:26PM
Storken Registered Member #1960 Joined: Thu Feb 05 2009, 11:57PM
Try 20-30 ohm. That risetime is waaay to slow - how does your gate drive circuitry look? inductance here must be minimized.
