  • Guests: 57
Banana Man (41)
TheAnomaly (13)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
Transformer B-Field Calculator
Adam Munich
Thu Nov 08 2012, 07:26PM Print
...Because I could barely find the formula; let alone a calculator!
Enjoy.
Daedronus
Thu Nov 08 2012, 10:05PM
midpage?
Fri Nov 09 2012, 03:01AM
Strong work, Gren.
I like that you give the formula. IMHO, formulas given without an online calculator are better than online calculators given without a formula. I've found plenty of calculators that give wrong answers, even for reasonable input values. The two in this thread seem to give the same answers.
The B-max formula is not hard to get from basic EM principles, if you work in SI units and remember that μ0 = 4pi/10^7 henries per meter. In MS Excel, you can type =4e-7*pi().
[edit]
Last night I wrote too late, and said an identical unit for μ0 was webers per volt-second. Wrong!
The SI unit of magnetic permeability is, indeed, the henry per meter.
That's identical to the "tesla per (ampere per meter)", as in μ = B / H.
But magnetic permeability has no place in the transformer core B_max formula.
That formula is an application of Faraday's law of induction: V = dΦ/dt.
Volts "per turn" = webers per second, so webers = volt-seconds.
SI flux unit: 1 weber is 1 tesla x 1 square meter; same as 10^8 maxwells.
cgs flux unit: 1 maxwell is 1 gauss x 1 square cm.
Flux change of 1 maxwell induces 10^-8 volt-seconds.
Gren's calculator gets an extra plus for having coefficients for both sine waves and square waves. Square waves have the lower RMS voltage for the same frequency and same flux swing (= integrated volt-seconds in one positive or negative half-cycle).
For |B_max| values close to saturation, you can squeeze out a bit more RMS voltage and peak voltage using "cresty" voltage waveforms. They form automatically if a sinusoidal primary voltage is too high (by, say, a factor of two), and the primary current is limited by a resistive ballast.
