  • Guests: 54
Banana Man (41)
TheAnomaly (13)
01/21 Banana Man (41)
01/21 TheAnomaly (13)
01/23 GimpyJoe (36)
So I got some mosfets...
macona
Tue Nov 06 2012, 08:59AM Print
macona Registered Member #3272 Joined: Mon Oct 04 2010, 11:40PM
I have been registered on here for about 2 years now and never have really posted.
Well, I got some mosfets the other day, think I need to build a SSTC:
8134450933 7f8c564156 C
IMG_1584 by macona, on Flickr
Any other ideas? Lots of SOT packages and larger TO packages. Even some all-metal TO packages. Most (~99%) test out OK for basic on/off. Going to build a test fixture that will put them under more of a load.
-Jerry
Tue Nov 06 2012, 02:50PM
Did a store go out of business? How did you get so many random mosfets?
Microwatt
Tue Nov 06 2012, 04:42PM
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
wow you can switch some big time power there.
Chip Fixes
Tue Nov 06 2012, 05:20PM
I'm a little jealous right now....
Tue Nov 06 2012, 05:28PM
You lucky SOB !
macona
Wed Nov 07 2012, 09:56AM
I am not too sure what the exact story is. There were a couple 55 gal drums (Gone now) full of these that were brought in by a scrapper. Some are unmarked, some have sharpie marks on them with numbers. Best guess these were production test samples, the company that makes them is a couple hours away.
I got most of a 5 gal bucket of them, a friend bought about 190lbs of them. He does a lot of stuff with motor controls and power control. I figure I will never have to buy another mosfet again.
Wed Nov 07 2012, 01:16PM
APT make some nice metal gate MOSFETs rated up to 10s of MHz. I'd check to see if you have any of those.
Electra
Wed Nov 07 2012, 08:43PM
The square ones with 4 screw holes look nice for high power if you can identify them, most appear to have markings which is good.
If they came from a manufacturer, they may not have met some min spec in the datasheet and were rejected, though they probably will work for most purposes.
Maybe get a few people to help you sort them in to like for like piles, test a few bag fulls of each at a time, so you have some ready to use.
ShawnLG
Wed Nov 07 2012, 09:03PM
You hit the motherload! I guss they are rejects from the manufacture. They do not meet their specs.
teravolt
Wed Nov 07 2012, 10:46PM
Maybe a small test jig is in order. they may be in a can for a reason. That would be where I would start. A stiff 50-100v power source and a load resistor and a 20v power supply is all you need.
