  • Guests: 68
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
arduino is for idiots
1 2 3 4  last
Microwatt
Sun Nov 04 2012, 07:20PM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
I think arduino is for people who don't have the ability to put together a comparator and resistors . nuff said.
genious 7
Sun Nov 04 2012, 07:46PM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
Nah, I guess it depends on the user. 90 % of the users are used by people who do not have the ability of using a comparator, as you said.
I mean, I've seen too many projects for which they use an arduino when a 555 was enough. However, every now and then a really good project which uses an arduino appears. If I said Atmel micro controller development board, you'd probably say its ok, if I said Arduino, you'd shout noob.
Storken
Sun Nov 04 2012, 08:51PM
Storken Registered Member #1960 Joined: Thu Feb 05 2009, 11:57PM
My class just had a touch project, just to prove the concept. Complicated circuit boards, 555 timers, comparators dominated - parts count was overall high. I finished this project with a single sided pcb, one resistor and a header to interface to a xplained xmega microcontroller.
Not only was the current consumption of my circuit waaay lower (due to the 25Hz update rate), it also had the highest Signal to noise ratio of all the systems. I could go on.
I could say: I think comparators and resistors are for people who don't understand microcontrollers.
But then again, that is from my point of view.
2Spoons
Sun Nov 04 2012, 09:18PM
Microwatt wrote ...
I think this is a silly statement.
Sometimes a micro is justified , sometimes it isn't. When it is justified it can make more sense to buy a standardised platform and build on from there. No point reinventing the wheel.
Dr. ISOTOP
Sun Nov 04 2012, 10:14PM
Microwatt wrote ...
Microcontrollers consolidate fairly large, possibly unreliable, possibly expensive digital circuits into a single chip that can be reprogrammed in case of improvements or errors.
How is that only for idiots?
Mattski
Sun Nov 04 2012, 10:17PM
Microwatt wrote ...
Perhaps sometimes you're right that Arduinos are used where a simple analog circuit would suffice, but the Arduino is still a nice platform for people who just want to build projects that call for a microcontroller but don't want the headaches often associated with microcontrollers. There's a lot more to DIY engineering than messing around putting together a microcontroller board with power supply, oscillator, peripherals, and getting code to compile properly and programming it onto a chip. Arduino makes that stuff easy so that people can focus on building more complex projects.
BigBad
Sun Nov 04 2012, 10:57PM
My father (a hard core electronics engineer) has just about finished building a complicated interface using an arduino to interface PCs to legacy test equipment.
I'd love to see you try to do that with a couple of comparators.
Daedronus
Sun Nov 04 2012, 11:06PM
IMHO Arduino IS a crap re-branding of a fine microprocessor.
The AVR micro itself is nice, and AVR studio is more then fine for programming them, and it's also free, unlike the crap tools for PIC micros.
But the whole Ardushitino is just BS re-branding and hype to make $ ....I think...
Microwatt
Sun Nov 04 2012, 11:36PM
Mattski wrote ...
Microwatt wrote ...
what sort of complex projects have you seen done with a shitino? I went to my local hackers space and everybody was doing an arduino project. I think it makes electronics too user friendly.
Mon Nov 05 2012, 12:17AM
Microwatt wrote ...
12kw induction heater, self-locking resonance
Capable of levitating aluminum, steel and copper. Capable of serving as a furnace for a blacksmith who needs to uniformly heat pieces of steel as small as a knife to as large as a full-sized sword. This project required a microprocessor. If you look at the schematics at the end of the tutorial you can see how it was worked into the project. There are YouTube links so you can see it in action.
1 2 3 4  last
