  • Guests: 41
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
ZVS Mazzilli induction heater
mohiuddinHimel
Tue Oct 09 2012, 01:06PM Print
mohiuddinHimel Registered Member #4254 Joined: Sat Dec 10 2011, 09:36PM
Hey guys i was currently working on a ZVS induction heater of this circuit
When i read different forum posts on ZVS induction heater, i saw many people complaining about Mosfet failure. Now um getting depressed even before building it :(
Is there any precautions that should be taken to avoid these problems???? Any suggestions??
my parts:
IRFP260N (two in parallel)
470 ohm 5watt resistors
10K 2 watt resistor
12 volt zener 1 watt for each mosfet
UF4007 1kV fast diodes
0.1X38 = 3.8 uF 640V MKP Capacitor bank
220/38 30 A 1000 watt transformer
1000 V 50 A bridge rectifier
Filter cap 47000 uF 100 WV
Please help!!!!
Tue Oct 09 2012, 04:57PM
from what ive learnt, paralleling can be a bad idea unless they are perfectly matched. Good luck!
mohiuddinHimel
Tue Oct 09 2012, 05:43PM
__=|(:3)-|--{__ wrote ...
hey thanks,
btw what do you mean by perfectly matched?? Would you please explain a lil bit?
Tue Oct 09 2012, 05:50PM
I think it is OK to parallel mosfets.
mohiuddinHimel
Tue Oct 09 2012, 09:31PM
Dr. Dark Current wrote ...
Here is the circuit i am planning to build. Does it look okey?? Is there any improvement i should make??
Parallel ZVS
Hellraiser
Wed Oct 10 2012, 04:50AM
Hellraiser Registered Member #2925 Joined: Sun Jun 13 2010, 06:38PM
Hi, we all want more power, i have here some units of IRG4PC50UD, IGBTs so i was thinking what kind of modifications i might need do for use them in this Mazzili ZVS driver.
Storken
Wed Oct 10 2012, 12:14PM
Storken Registered Member #1960 Joined: Thu Feb 05 2009, 11:57PM
For higher power: go with a LCLR setup, a half bridge driver, some beefier mosfets and perhaps most importantly: find a way to regulate power and adjust frequency according to workpiece. Mosfets don't last long in capacitive region.
My way: Allegro IC current sensor connected to a AVR giving frequency out. Allways keeps the tank in the inductive part, witch keeps the inverter happy :)
mohiuddinHimel
Fri Oct 12 2012, 08:14PM
a simplified circuit. I'll use ferrite bead around each mosfet's gate along with a 10 ohm gate resistor.
Is there anything else to improve?? ANY SUGGESTIONS ?????
1 Copy
mohiuddinHimel
Thu Oct 25 2012, 02:12PM
here is a video of it working at 1000VA input....the power output disappointing. Next one will be h bridge LCLR heater capable of 15 KW.
Video
