  • Guests: 60
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
True buck-boost bootstrap question
Storken
Thu Jul 12 2012, 12:20PM Print
Storken Registered Member #1960 Joined: Thu Feb 05 2009, 11:57PM
Hello, I'm working on a true buck boost converter. I tried simplifying some of my drawing so that it would be easier to understand. The original schematic includes a 3-ph mosfet driver with bootstrapping circuitry, so I hope you still understand what I'm trying to achieve.
Basically, it seems that the bootstrap charging path needs to go through the main inductor, does this pose a problem for operation?
1342095570 1960 FT0 Bootstrap
colin
Thu Oct 25 2012, 03:27PM
colin Registered Member #7130 Joined: Tue Oct 09 2012, 03:08PM
Hi
Input Rail should go through Inductor at first instance. This will charge the inductor. At second instance when mosfet switches the circuit to the out put then load should be connected through capacitor. Means when inductor is charging capacitor is supplying power to the load and then Inductor supplies power to the load then capacitor must be charging. Shortly ; Replace L1 with D2.
electronic assembly
