  • Guests: 37
Kolas (18)
Dillon4DynamicHarmonics (41)
12/25 Kolas (18)
12/26 buxtronix (50)
GDT driver
Redstone
Wed Sept 12 2012, 02:47PM Print
Redstone Registered Member #2578 Joined: Sun Dec 27 2009, 09:21PM
I would like some help with figuring out why the wave form on the IRF740 gate looks really bad when the frequency goes below 48khz. it is not a sudden drop off, it slowly changes into the first one. I have tried different component values, yet it still looks bad. I am thinking of putting a resistor value on the gate of a transistor in the totem pole.
I have drawn the schematic and the two wave forms, I am not an artist. the wave form that has a one to the left is the wave form at 24khz. the one below with the number two to the left is it at 48khz
1347460543 2578 FT0 Capture
Don't anyone tell me it can't be done and do not even think of using an IC!
Here is the resouce Link2 it is under transformer coupled gate drives near the bottem
Wed Sept 12 2012, 03:02PM
You need flywheel diodes across your transistors to return the magnetising current to the supply. The lower you go in frequency, the worse the magnetising current gets.
Dr. Slack
Wed Sept 12 2012, 04:58PM
What's the 1N4148 across the 740 gate doing? I mean, what's it meant to do, and what's it doing?
Redstone
Wed Sept 12 2012, 05:00PM
Ok looks nice now, How can I square this up? I am thinking run the voltage up on the totem pole to 25 volts and use a 15 volt zener on the gate.
1347469117 2578 FT144381 Capture2
go though the link in my first post and read a little. it explains it many times better than I can
Wed Sept 12 2012, 05:14PM
Would adding flywheel diodes on 2SD965/2SD1812 based CCFl inverters stop them catching on fire when drawing arcs from the output?
I tried limiting the current, adding series capacitor, you name it. No go.
Wed Sept 12 2012, 05:16PM
once your significantly above the threshold voltage on the gate, does it matter if it droops out of square a bit? (as long as it remains above Vgth)
Redstone
Wed Sept 12 2012, 05:17PM
Same thing I was wondering
Wed Sept 12 2012, 05:28PM
Vgth moded for your wave form:
1347470882 2431 FT144381 Sqw
Once significantly above the red line (from your part numbers' data sheet) it should be ON in, low resistance. Once below, the transistor should be a resistor getting hot or totally OFF.
Wed Sept 12 2012, 07:12PM
The gate threshold voltage is when the FET or IGBT starts turning on. It is insufficient if the gate voltage is just above this threshold, it must be high enough to fully saturate the transistor. This usually happens with >10V for a MOSFET or >12V for an IGBT.
GeordieBoy
Wed Sept 12 2012, 07:34PM
LF droop is either caused by too few turns on the GDT, or too small AC coupling capacitors...
Things to try:
1. Put more turns on GDT to increase magnetising inductance and decrease magnetising current.
2. Increase the capacitance of the 0.1uF AC coupling capacitor. This value sounds too small anyway.
3. Increase the value of the 10k DC bleed resistor.
The 1N4148 diode causes the balanced bi-polar voltage appearing across the transformer secondary to be converted into a uni-polar drive for the MOSFET. It results in the 0.1uF capacitor charging on one cycle of the GDT waveform, and then adding this DC voltage to the GDT waveform on the following cycle. It works like the voltage doubler used in a microwave oven power supply circuit. Operation with GDT summarised below:
GDT waveform exists from v- to v+
results in capacitor charging to voltage v (minus one diode drop!)
and MOSFET gate voltage going from 0 to 2v (again minus one diode drop) when done properly smile
Actually figure 35 in that Unitrode application note listed in the OP's message explains it quite well.
In practice it takes several cycles to get the 0.1uF capacitor charged up so it works best in CW applications. It's not good in pulsed burst applications because the MOSFET may not get sufficiently enhanced to carry large load currents at the start of the burst of gate drive!!!
-Richie,
PS. You should also have a ceramic and 10uF-100uF worth of decoupling capacitance across the power rails right at the gate-drive transistors draw their current from the supply. Otherwise the fast switching of the transistors will bite chunks out of the supply rail voltage.
