  • Guests: 48
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
Add your dinosaur here.
Sat Sept 15 2012, 07:13AM Print
Hi all.
Feel free to add to this thread with your most ancient grizzly piece of test gear.
Valves, tunnel diodes and ancient woodworm ridden casings welcome.
Special credit for home built stuff, especially if pre-Intel.
I have a Robin pocket multimeter here, it still works (!) once recalibrated.
It appears one of the diodes drifted but other than that all works fine.
A few scratches and dings but once the cover was Liquid Poly'd back
together it looked fine.
Also have an antique grid dip meter using a valve.
This is older than I am (!) and amazingly even though it has been butchered by
its previous owner it still works.
-A
Hazmatt_(The Underdog)
Sat Sept 15 2012, 09:14PM
I've been repairing this one for a while. Few things are older then General Radio and Boonton.
This is a General Radio 1233-A power amplifer. Audio and HF frequency amplifier, full power output is roughly 25W.
Full tear-down of old capacitors and hardware, basically gutted. I decided to get the input stage differential amplifier working again today because
out of all the things I could do today, most of them required going outside and its 104F right now, so why bother.
It has two sets of output transformers to handle the two frequency ranges, and the drivers are 807's, very reliable tube.
enjoy!
019f
020f
Tetris
Sun Sept 16 2012, 12:16AM
This multimeter is older than I am. 1GyXgl
It doesn't work, though. I have a new one. It was my first ever piece of equipment, I got it when I was 10 years old, my dad's old meter. I think it was what got me into electronics. :D I used to make coin batteries and test them. I loved this meter. I lost it in early 7th grade, and tore up the house looking for it twice. At the second time, I told myself I'd find it when I moved, and June 8, when we moved, I found it. Well... my mom did. I was very happy, but I already had a new meter with many more functions. :P
I also have had an ancient oscilloscope since I was 9. My dad told me then: One day, you'll love electronics, and you will want it. Oh how right he was. It doesn't work right though, and it's an old analog one. I have no idea how old it was at first though.
Sun Sept 16 2012, 08:44AM
Probably bad capacitors or a defective input stage, easily fixed.
Killa-X
Sun Sept 16 2012, 08:20PM
Well, I didn't feel like filling a page with images so links instead. I do not own this anymore, I donated it to the geek group to have it in their museum when it's built, personally delivered. This old meter doesn't work because when I turned the switch it seriously busted into a thousand parts. It was horribly fragile. I got it for 20 bucks. Enjoy..
It came with origional manual and test leads as well.
Two batteries powered this.
And a 10 cent battery
Made by acme ( not to be confused with cartoons acme ) dated 1944 best used by :)
Mon Sept 17 2012, 02:34PM
Heh..
Really must post picture of the guts, despite its age this meter is fully working.
I am amazed that all it needed was its offset resistor adjusting, for some reason it drifted a quarter turn in one direction.
