  • Guests: 61
12/25 Kolas (18)
12/26 buxtronix (50)
discharging a 3nF HV capacitor through a coil
Yanom
Mon Sept 10 2012, 01:34AM Print
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
I saw on HvWiki that it's possible to make a homemade capacitor. Tiny capacitance, like 3nF, but it could handle up to 60kV(!). As an interesting thought experiment, i pulled up Barry's RLC sim to see what would happen if I used this as a capacitor on my coilgun.
The sim says that, due to the "ringing" of the coil, there would be an (essentially) 14kHz AC current through the coil. 14kHz is radio frequency! I don't know much about radios and how they work, but would this generate radio waves / interference of any kind?
Inducktion
Mon Sept 10 2012, 01:42AM
Definitely. You'd be making essentially a mini radio oscillator circuit. Of course the oscillations would die down really quick. You'd be making a little "ping" on radios, if you could get the frequency up higher.
Yanom
Mon Sept 10 2012, 02:46AM
Inducktion wrote ...
interesting. So I don't need any sort of antenna. And.... how do antennas work anyway?
Bored Chemist
Mon Sept 10 2012, 07:56PM
" 14kHz is radio frequency!"
Kind of.
You can hear sounds at that frequency.
It seems rather low to me.
Yanom
Mon Sept 10 2012, 11:56PM
Bored Chemist wrote ...
interesting. So I would hear a high pitched squeal if I fired this thing?
Shrad
Tue Sept 11 2012, 06:28AM
quite close to the "pouuiiiiiiiiii...." you can hear when a modified hartley oscillator based capacitor charger like a photoflash unit slowly changes frequency as the resonant frequency of the system is increasing with output impedance, but inverted as it discharges in place of charging
cduma
Fri Sept 14 2012, 02:15PM
The transient period would be so short there is no way you could actually hear anything more than a pop on the radio.
