  • Guests: 33
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
Questions about I and T beams, material stiffness and strength.
Thu Aug 30 2012, 02:07AM Print
what is it called when the cross section of a beam is optimised like an H or T beam, is it area inertial moment? Im an EE student and my ME's are in class this week so im kinda on my own here...
im trying to build light weight but stiff stuctures using ribs, beams, or spars or what have you. Im mostly interested in stiffness, strength, and low cost (minimum material).
Thu Aug 30 2012, 07:07AM
We called it second moment of area. However, when designing a structure you also have to consider resistance to buckling. For instance take a T section and an I-beam of the same second moment. The T section will buckle easier under some conditions.
Box sections and tubes are good all-round building blocks.
Thu Aug 30 2012, 04:17PM
ok i am thinking of using fiberglass layers on styrofoam or balsa, becuase im using way to much carbon fiber and fiber glass.
in my previous builds, i have way more strength present, then is actually being used, and its still not stiff enough. and CF is expensive, so i must optimise the cross section for my purpose.
Thu Aug 30 2012, 04:39PM
Yes, a honeycomb, balsa or foam core will increase the second moment greatly by moving the strong material away from the neutral axis.
Thu Aug 30 2012, 04:55PM
Steve Conner wrote ...
ok thats what i thought, but i didtn know it was called a neutral axis, thats where the strong material contributes least to strength and stifffness, yet proportionally to mass.
The balsa also helps resist buckling of the thin (single layer CF/FG) walls out of parallelism/perpendicularity while under load, even though the balsa i use has no real strength.
Thu Aug 30 2012, 07:23PM
You got it! smile
Thu Aug 30 2012, 09:17PM
pics
1346361467 2431 FT143921 Sam 0139gbody
CF on 0.5 inch styrofoam, M10A grenade (inert) and scissors for scale...
1346361468 2431 FT143921 Sam 0140gcf
2 CF layers on the bottom, 2 on top, 4 layers total. 0.5 inch styrofoam visible. Still too flimsy, i now realise i used to much of my hi-$ CF, and still dont have the stiffness i need. Dam it.
1346361468 2431 FT143921 Sam 0119ipiece
single layer CF wrapped on both sides of 0.25 inch thick balsa, very light, very stiff.
1346361468 2431 FT143921 Sam 0120ih
A close up while wet. 0.012" thick times two layers. 3k tow, 2x2 twill, 644 Ksi AS4.
abcdef
1346362456 2431 FT1630 Sam 0144b
Ducted lift fan for tilt rotor... 11 inch dia. prop, 12 inch dia. duct...
1346362456 2431 FT1630 Sam 0143a
Closeup, bass wood on the servo holder, FG and foam for the duct.
1346375925 2431 FT1630 Sam 0148c
servo and bass wood mount...
