  • Guests: 48
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
bicycle and similar cables...
Wed Aug 29 2012, 04:46PM Print
does anyone know what those bicycle cables are called that have the black plastic and coiled metal sheath, then has a small diameter steel cable in the center.
i presume there are standard sizes and form factors ?
Harry
Wed Aug 29 2012, 04:55PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
Is that the type used for changing gears or braking?
And yes, they come in standard sizes, I think there are 4 or 5 major types of cable commonly available.
Ash Small
Wed Aug 29 2012, 06:00PM
Bowden cable.
Wed Aug 29 2012, 06:06PM
yes for shifting and braking, though i plan to use them for other robotic purposes.
ok let me look up "bowden cable"
EDIT: bingo! Link2
Wed Aug 29 2012, 07:04PM
Patrick wrote ...
The name is new to me. Thanks, Ash.
Patrick, be sure to note the critical difference in construction
between cables to transmit substantial tension force (e.g. for braking)
and cables to transmit precise displacements (e.g. for indexed shifting).
I don't know if the Bowden cable name includes flexible cables to transmit rotation, e.g for speedometers.
Wed Aug 29 2012, 07:57PM
klugesmith wrote ...
excellent points, ill remember them.
im trying to push and pull a rotating body, + and - 45 degrees.
Ash Small
Wed Aug 29 2012, 08:24PM
The best solution would be two cables, both pulling on the ends of the cross-piece of a 'T' shape that pivots at the intersection.
Wed Aug 29 2012, 08:43PM
Ash Small wrote ...
yes, thats what i was thinking, plus again on the servo wheel.
