  • Guests: 59
David (39)
12/25 Kolas (18)
12/26 buxtronix (50)
Does this capacitor ESR chart look accurate?
Yanom
Wed Aug 22 2012, 09:45PM Print
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
this chart
do those values look reasonable? Also, it says that "ESR generally decreases with increasing temperature." This strikes me as odd, because resistance in most materials increases when you heat it up.
also see this chart [PDF]
Thu Aug 23 2012, 04:16AM
Yanom wrote ...
Do those values look reasonable?
Have you tried looking up some real OEM data sheets for electrolytic capacitors, and compared their specs against the chart you cited?
Here's a challenge. Go here: Link2 and give us a report.
Yanom wrote ...
But the resistance generally decreases in aqueous electrolytes as they get hotter.
Yanom
Thu Aug 23 2012, 02:28PM
klugesmith wrote ...
those ESR values are for a 120Hz AC current, and they're significantly higher than the (presumably DC) values on my chart(s). However, the general theme seems to be that:
-larger caps have lower ESR
-ESR is greater at higher voltages
aaand...
did not expect any of those things. How does resistance go down when they get hotter anyway?
Mon Aug 27 2012, 02:06AM
Umm... DC current for capacitors? If the voltage isnt changing (DC) then the current into the capacitor is??? Most cap manufacturers spec both a 120/100hz mains ripple current and 10khz for a general idea of how it performs in a switching supply.
Id guess that its greater mobility of the ions that carry the charges. The cold just slows them down.
GeordieBoy
Tue Aug 28 2012, 10:51AM
ESR for electrolytic capacitors rises with age and also rises with decreasing operating temperature. That is one of the main reasons why aged switch-mode power supplies seem to always fail during power-up.
As the electrolytics in the supply age they dry up and ESR gradually to creeps up. However, as long as the supply is kept running the ripple-current through the capacitors ESR keeps the capacitors warm and the ESR doesn't get too high. But, if you switch off the supply, the capacitors cool to ambient temperature and the ESR jumps up noticeably. Particularly if the ambient temperature is down near freezing temperatures. In this case the re-application of power usually results in unstable operation and failure to start as the ESR is now outside of operational limits for the supply.
If you are really desperate to get an old SMPSU that has failed in this manner to start, you can often *GENTLY* heat the caps with a hair-dryer (NOT a hot hair gun!!!). This can often lower the ESR of old electrolytic capacitors enough that the supply will then start up when power is applied. Once the natural ripple current from the supply is running through the caps it may then continue to work for many more hours or even days. But eventually, ultimate death of the PSU is imminent so the caps or supply entire should be replaced ASAP.
The high ESR of electrolytics at low temperatures is another reason for the use of tantalum caps in SMPSUs for harsh environments where low temperatures are expected.
-Richie,
