  • Guests: 32
Will T (16)
william L (29)
Tipiment (62)
12/16 Will T (16)
12/16 william L (29)
12/16 Tipiment (62)
600 Amp 1200 Volt Rectifier Upgrade
Ash Small
Sun Aug 19 2012, 02:40PM Print
WORK IN PROGRESS
I'm finally getting round to re-building my rectifier after blowing up the diodes.
1345387234 3414 FT0 Dscf0683
This is the front panel of the (now defunct) rectifier. For an idea of scale, the terminal studs are half inch, silver plated, with matching nuts and washers, from a sub-station transformer. The insulating board is from the same transformer. It currently has a Lister 80A ammeter and Lister 500V voltmeter. AC input is on the left hand side terminals, positive out is the third terminal, and negative out is on the far right. Front and rear panels are 3.2mm (1/8") 316L stainless steel. I plan to re-use the front and rear panels for the upgrade.
These are three of the 300A 1200V diodes I am using for the ugrade:
1345392482 3414 FT1630 Dscf0691
(I'm just looking for the other one)
Datasheet is here:
]diode_datasheet.pdf[/file]
I was building purpose designed heatsinks from scratch, but ran out of money (out of 1000 series aluminium, I need ~£250 to get them finished). A fellow 4HV'er sent me 8 of these heatsinks:
1345397321 3414 FT1630 Dscf0696
(Thanks Neil smile )
I'll use two per diode, mounted on a 10mm aluminium plate, with the diode mounted in the middle. Cooling fans are 120mm 12V 0.3A. I'm not sure yet whether to have them blowing or sucking.
I want to be able to monitor the temperatures of the diodes this time, so I will be mounting thermo-couples (or thermo-piles) in holes drilled in the heatsink base-plate as close to the diodes as possible. I'll probably use type 'T' thermo-couples (constantan/copper). I found these level meters (which apparently have an FSD of around 200uA, with deflection of ~100uA to the 'red line') at a hamfest last weekend for £1 each:
1345400377 3414 FT1630 Dscf0698
Designing suitable circuits to get the meters to enter the red at around 100-125 degrees C will be the hardest part of this project. (With the possible exception of working out how to fit the meters into the existing front panel of the rectifier smile .)
TO BE CONTINUED.........
Sun Aug 19 2012, 03:27PM
nice! thats some heavy duty equipment, got any pictures of inside? im curious now!
Ash Small
Sun Aug 19 2012, 04:48PM
__=|(:3)-|--{__ wrote ...
It's a bit of a mess inside at the moment, and it's not that relevant to the upgrade I'm doing, so I won't include it in the first post of this project thread, but here it is, Tom:
1345394536 3414 FT1630 Dscf0694
(note the 10mm and 1/2" plates I used as heatsinks first time around)
Sat Sept 15 2012, 07:40AM
neat! whats your plan to use it for then?
Ash Small
Sat Sept 15 2012, 11:22AM
Well, apart from mains rectification for a 5kW, 50kV full bridge power supply and other projects I'll use it for DC TIG welding and various eectro- chemistry projects (electro-polishing, electro-etching, electro-plating, etc.)
Sat Sept 15 2012, 01:55PM
Nice, be sure to post pictures when its all working and build progress.
Electroplating is an interesting project, because you can do so much with that one electrolyte bath.
Even awkward metals like Ti can be plated if you use the right chemicals, IIRC the chemistry is non aqueous electrolyte/ion carrier like the one used in Li+ batteries.
Ash Small
Sat Sept 15 2012, 04:25PM
Conundrum wrote ...
I seem to remember finding a 'recipe' for electropolshing Ti years ago that involved some very complex organic compounds.
Ash Small
Sun Jan 26 2014, 12:35PM
The fourth diode has finally turned up, it was hiding in a box in the shed since I moved house over two years ago. It's now re-united with it's siblings, and I can continue with the project. Watch this space smile
1390739721 3414 FT143537 Diodes
Sun Jan 26 2014, 01:47PM
Horray, looking forward to seeing progress on this, also waiting to see your other project, the 5kW smps :)
Ash Small
Sun Jan 26 2014, 02:17PM
Thomas W wrote ...
I need this to supply the rectified mains for the SMPS, among other things.
