  • Guests: 99
08/24 voltek (49)
08/24 DJ Cosmo (17)
08/24 n8 (39)
Low voltage MOT power supply
Sat Feb 03 2007, 04:30PM Print
This is my first real power supply, so now I can finally start doing some serious projects. I built it to be indestructible, and so far not even a direct short can wreck it. Currently the max power it can supply is around 480W, because of the wimpy 10A rectifier I had on hand. I was planning on a full kW, but maybe another time. Output voltages are regulated 5 and 12v at 2A and 50 volts at 9A. The regulated 5 and 12 volts are provided by 3 pin voltage regulators. The filter cap is a bit small on the 50 volt rail, but I doubt the ripple will be a problem. Short circuit protection is provided by a current sense resistor and flip flop, after tripping it can be reset by a switch or turning off the power.
1170520199 95 FT0 Mot Psu Side
1170520199 95 FT0 Mot Psu Above
1170520199 95 FT0 Clamped Mot
1170520199 95 FT0 Mot Power Supply Schematic
Bjørn
Sat Feb 03 2007, 05:04PM
There might be a problem if you short the 50V to 12V or 5V so it is not completely indestructible.
Sat Feb 03 2007, 08:04PM
Crap, I never thought of that... I'll just have to make sure it never happens then.
TheMerovingian
Sat Feb 03 2007, 11:18PM
Simply place a strand of fuses
3A on the 5V and 12V and 15A on the 50V line
also place a 3A fuse on the mains (or 6A if you are a 110Vac-er)
Newton Brawn
Tue Mar 04 2014, 03:42PM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
This is a nice project,
It allows you to understand the MOT Sciece and Practice.
Regards
