  • Guests: 45
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Machinability of ferrite materials
Ben Solon
Sat Aug 18 2012, 03:31AM Print
Does anyone know how well(or disastrously) the machining of a ferrite core would go using a carbide end mill? I've tried sanding and fringing them before, and to some degree it worked, but the nature of such techniques are crude and inaccurate. I think I'll try to mill out the air gap with my end mill, but not if it's going to shred my bit frown
If anything its going to be a spark show. Any points? I would just find some machining forum or something, but I don't think most people other than ee's and magnetics experts know much about the material.
Sat Aug 18 2012, 05:35AM
I know that Ferrite is ok to grind/sand etc.
but I think that it is too brittle to machine
Dr. Slack
Sat Aug 18 2012, 07:42AM
I've seen machinable ceramics advertised, but then as you say, that's more mechanical than ee material.
"Mill out the airgap"? Does that mean put a gap into a flush core, or make a gapped core flush?
Either way, you might be better off with the grinding route. Get a SiC wheel ("Green Grit" in some juristictions) rather than Alli oxide, and rig up a holder for the core, or a holder for a light weight spindle, so you can manouvre the core and wheel with some precision. I bolted my grinding spindle into a table saw, bath-sealanted my cores to a flat board, and then passed them over repeatedly, removing packing as I approached the thickness. Note that ordinary printer paper stock is about 100um thick, and Rizlas are 1 thou.
Ash Small
Sat Aug 18 2012, 09:56AM
I would also advise the grinding route.
Commercial winders use grinding to produce the airgap.
I would also advise using water/cooling fluid while grinding if at all possible (obviously water and electricity don't mix, so use some common sense).
However, take your time and don't rush it.
2Spoons
Sun Aug 19 2012, 10:09PM
Definitely go with the grinding wheel. One thing I've noticed when doing this my self was that the outer surface was noticeably harder than the inside.
Ben Solon
Mon Aug 20 2012, 12:07AM
2Spoons wrote ...
Yes, from my experienced with a core and a dremmel cuttoff wheel, I can second that. It doesn't matter so muh anymore because the guy at the recycling center let my friend and I sit in the box with all the tvs and gather flybacks XD. I found 4 that where gapped with plastic shunts on both sides, so it's not much of an issue anymore. Plus I found a good lot of huge heatsinks from an old Sony projector!
