  • Guests: 72
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Which oscilloscope?
MonkeyMad
Fri Aug 17 2012, 09:51AM Print
MonkeyMad Registered Member #5598 Joined: Thu Jul 05 2012, 11:18PM
Long story cut short. Because I don't have access to a scope for physics I have been given an equiptment grant to buy one up to £1000. I would like some advice as I have never owned one before on a good one for a complete newbie!
I would also like if possible to be able to use it for my own electronics projects in the future once I become a bit more competent.
I know that this is probably a very broad question buti have no idea in this area and need it for October. So I shall be looking intoit more myself too but any advice muchly appreciated.
Thank you.
Danny.
Fri Aug 17 2012, 12:44PM
Well, i would recommend getting a Tektronix.
Are you looking to buy a new one or a used one, or does it not matter?
The Tektronix DPO series is a very nice series. There should be several scopes in that series that falls within your budget.
These have screen capture, math functions, fourier reponse, and much more more.
Sat Aug 18 2012, 12:40AM
If you're going to spend that amount of cash you should choose wisely,
features vs. performance, do you know it's long term requirements?
when it breaks/is broken who will repair it, or will it be binned?
check warranty period and terms etc.
if you have technicial services see what they can repair,
3rd party could be beyond economical repair.
Or be very careful
or learn to repair 'scopes ;)
also;
consider probes .. digital, current, differential, high voltage or whatever
... quite a bit of that budget may go to probes etc.
or can you get a 'probes' budget later allowing the 'best' scope possible ?
P.S. 'scopes are pretty reliable, probes wear out/die
