  • Guests: 51
Inducktion (32)
Standa (31)
nabzim (33)
12/23 David (39)
12/25 Kolas (18)
Natural Exploding Wire - a massive Russian lightning bolt vaporizes wire connecting two buildings
Bert
Sat Aug 11 2012, 02:11PM Print
Bert Registered Member #118 Joined: Fri Feb 10 2006, 05:35AM
Amazing video and image of a powerful lightning strike vaporizing a wire that was strung between two buildings in Russia. Captured from two different perspectives, the steel support wire is explosively vaporized in a shower of sparks. Also evident is more aggressive vaporization along the shorter path:
Exploding wires are loud.... lightning-exploded wires are VERY LOUD!
radiotech
Sat Aug 11 2012, 06:31PM
Why was the wire strung between those two buildings and what evidence is there that
it vaporized?
Sat Aug 11 2012, 06:47PM
Amazing , especially the pics amazed
Lightn10
@radiotech : the yellow things we can see a few meters around the cable are droplets of liquid/burning metal.
Bert
Sat Aug 11 2012, 07:42PM
radiotech wrote ...
it vaporized?
As I understand it, a fiber optic link had been strung between the tops of the two buildings. This is apparently a rather common practice in that part of the world. The link was mechanically supported by a steel cable, and it was the latter that conducted the discharge current, exploding in a shower of burning-steel. The non-conductive fiber link can be seen as a faint dark line spanning the gap in the still images (before it fell). From the volume of sparks produced (those are 18 story buildings!) it must have been a pretty stout cable. Interestingly, the ultrabright flash that accompanies true wire explosions (channel reignition and follow-through current through the air-metal plasma) was not present. So, this may not have been a true "exploding wire" event - just a very energetic disassembly of the cable... smile
Sat Aug 11 2012, 08:35PM
Scott Fusare Registered Member #531 Joined: Sat Feb 17 2007, 10:51AM
Outstanding Bert! Thanks for sharing.
Scott
Microwatt
Sun Aug 12 2012, 02:02AM
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
how much energy do you think was expended in the cable?
Antonio
Sun Aug 12 2012, 01:28PM
It's interesting to see the greater power dissipation at the shorter side of the cable. A nice demonstration of how power distributes between two parallel resistances.
Bert
Mon Aug 13 2012, 12:31AM
Microwatt wrote ...
Interesting question! I created a small spreadsheet to ballpark some numbers. I assumed that the support cable was made from 3/16" diameter stainless steel 302 cable. based on the building total height of about 20 stories (to top) and 10 feet/story), I estimated that the distance between buildings was about 400 feet. It looks like the stroke connected at a point 170 feet (short length) and 230 feet (long segment). Assume both ends of cable are solidly grounded. The electrical resistivity for SS 304 electrical is 72 microohm-cm, so the estimated resistance of the short segment is ~0.79 ohms, and the long segment is ~1.05 ohms. I guesstimated peak current and duration for "typical" positive and negative polarities using data from Bazelyan and Raizer's "Lightning Physics and Lightning Protection". For a negative CG strike, I assumed that the first return stroke peak current was 50,000 A, and its duration was 100 microseconds. For positive CG lightning, I assumed a peak current of 200,000 A and duration of 500 microseconds. Following is the estimated Joules/segment (simplistically asuming that cable resistance stayed constant vs temperature), and the estimated temperature rise for each cable segment for negative and positive CG strokes:
If "typical" Negative CG strike:
Wshort = 50 kJ in shorter segment
Est Temp Rise: 17.3 C
Wlong = 40 kJ in longer segment
Est Temp Rise: 9.7 C
If "typical" Positive CG strike:
Wshort = 5.16 MJ in shorter segment
Est Temp Rise: 2415 C
Wlong = 3.87 MJ in longer segment
Est Temp Rise: 776C
YMMV, but based upon the above results, it looks like the higher peak current and longer duration of a positive CG lightning strike is necessary to account for the observed results...
Herr Zapp
Mon Aug 13 2012, 04:26AM
Bert -
Aside from the lightning discharge and the vaporized conductor, there is an interesting image artifact very visible in your 3rd link (the enlarged still image).
All the illuminated windows in the high-rise buildings have a "smear" of light trending slightly up and to the right. However, not all the light sources visible in the image have this smear; some (like individual lamps in the foreground, at the bottom of the image) are crisp, with no "coma".
So the "smaers" of light don't appear to be the result of camera movement; what are we seeing?
Herr Zapp
Bert
Mon Aug 13 2012, 05:39AM
Herr Zapp wrote ...
Bert -
Herr Zapp
Interesting observations! However, I suspect the smears are indeed due to slight camera movement. The still camera appears to have been physically closer than the video camera. Perhaps the still camera was slightly shifted by acoustic blast(s). Some of the unsmeared light sources in the foreground appear to be reflections of the lightning flash, so smearing of these would not be expected. Others foreground lights, such as the automobile taillights, appear to be comprised of multiple (3-4) discrete spots that trace a similar trajectory as the smeared sources. I'd surmise that these are from the strobing effect of the pulsed taillight drivers used in modern cars. However, I can't explain why a single set of auto headlights (also in the foreground) does not appear to be smeared. Perhaps the car's movement partially compensated for the camera movement?
BTW, after reviewing the video clip again, multiple strikes are evident... so the bolt was NOT a single massive positive stroke. Statistically, a small percentage (1% or so) of negative CG bolts exceed 200 kA+ during the first return stroke, and 100+ kA on subsequent strokes. In between strokes, hundreds of amps of "tail" current may flow. Negative lightning has a higher di/dt so skin effect and current diffusion effects (not taken into account in my earlier simplistic analysis) may play a more profound role than bulk resistivity, especially for slightly ferromagnetic alloys such as SS 302/304. Flash surface heating/ablation of the cable's outermost layer may be the result.
This is one fascinating event, and is especially amazing since it was simultaneously captured in separate video and still shots! Some awesome pulsed power effects are at work here...
