  • Guests: 27
Cprossu (40)
Kokamo (46)
GalliumMan (60)
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
Lichtenberg Figures
AuroraFlame
Fri Jul 27 2012, 09:08AM Print
AuroraFlame Registered Member #5566 Joined: Tue Jul 03 2012, 10:55AM
Anybody understand what kind of power supply is being used to produce these captured lightning sculptures. They say its over two million volts but I find this hard to believe. I also don't understand why they need to be struck to produce this. Its beautiful the way it continues to spark even after the pulse has passed through the block of material.
Sigurthr
Fri Jul 27 2012, 12:10PM
IIRC they use an electron gun (in vaccuum) to shoot electrons in to the plastic to the point that they become embedded in high enough quantities that a massive charge builds up inside the plastic. I don't think 2million volts is applied to the electron injector, but rather the voltage between the charges inside the plastic is 2MV.
The reason it has to be struck to cause the effect is that the physical trauma causes a disruption in the system which avalanches. Think of the plastic block as an array of charged caps, and striking one is like shorting a cap.
Fri Jul 27 2012, 01:22PM
Bert Hickman makes beautiful Lichtenberg Figures. I have several i've purchased from him from various Teslathon events.
Be sure to check out his website. He has a wealth of information on high voltage, coin shrinking, and Lichtenburg figures he sells.
Pinky's Brain
Fri Jul 27 2012, 04:28PM
I wonder if it would be possible to bake in an electric charge into a polymer while it's hardening to get the same effect.
Fri Jul 27 2012, 04:42PM
It's done with a "Dynamitron" electron beam accelerator, as Bert says in his videos. Link2
The Dynamitron is designed for industrial irradiation, and it produces 5MeV electrons that can easily travel through a few feet of air. They also travel through acrylic, but only for a short distance before becoming lodged inside the plastic block. When the block comes out of the accelerator it is literally stuffed full of excess electrons.
Sat Jul 28 2012, 07:58PM
Beautiful results, I love this !
Wish small sparks could keep arcing indefinitely ^^
DrZoidberg
Sat Jul 28 2012, 09:19PM
DrZoidberg Registered Member #350 Joined: Mon Mar 27 2006, 05:14PM
Is it somehow possible to create something like that at home? Do you really need 5MV. Maybe 1 MV is enough for small pieces of acrylic. A small beam current of e.g. 1µA should be sufficient, you just have to irradiate the acrylic block for a while.
But I guess you would still need shielding around the setup to protect against x-rays.
It would be great if there was a simpler way to do this that doesn't require an electron accelerator.
What if you simply take a piece of acrylic and put positiv charge on one side and negative charge on the other? Could that work too or does the charge have to be inside the material?
Sat Jul 28 2012, 09:50PM
DrZoidberg wrote ...
Bert is one of the leading experts in high voltage in the United States. He has elaborate equipment for his coin shrinking endeavors and much much more. I'm sure if it could be done at home, Bert would have a way to do it. From speaking with Bert years back, he pays quite a pretty penny to rent time for the electron accelerator.
Pinky's Brain
Sat Jul 28 2012, 10:32PM
What exactly would happen if you put some uv curing polymer in a box with a HV electrode and a magnetic stirrer, letting it stir for a while and then curing it with an UV lamp?
Can the polymer store sufficient static charge to get destructive discharges when hit by a ground pin? If not, why not?
DrZoidberg
Sat Jul 28 2012, 11:48PM
Pinky's Brain wrote ...
If you have a 2MV HV electrode. But I think the ions inroduced into the polymer would quickly move to the surface.
