  • Guests: 41
Elliott (35)
Gratitude (40)
Swraka (37)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
Making thermocouples with HV!
2Spoons
Wed Jul 25 2012, 02:02AM Print
Producing a welded tip type K thermocouple is not so easy - a butane flame really doesn't get hot enough to melt the alloys. Soldering is somewhat unreliable, due to solder being so soft, and the need for an aggressive flux. Oxy-acetylene works, but a small flame is needed - we managed to make one successfully this way.
Then I remembered just how hot the termination point of an arc can get (by ion bombardment), so I dug out my old NST. With the thermocouple wires twisted tightly and connected to one end of the NST it only took a couple of seconds of arc to form a nice melted ball! This was all done with fine gauge Teflon covered Type K wire.
My workmate and I made 6 thermocouples in about 10 minutes this way.
Bjørn
Wed Jul 25 2012, 07:42PM
That sounds like a good idea. Do you have any pictures?
GeordieBoy
Thu Jul 26 2012, 11:35AM
Capacitance discharge welding is a long established technique for thermocouple manufacturing. The operator twists the dissimilar wires together and sets the discharge energy. When the go button is pressed there's a pop and a flash and the wires are spot welded together.
Often the same machine then invokes a TIG weld to fit the thermocouple cap to the barrel body and seal the complete assembly. Usually with a thermally conductive and humidity reducing poweder sealed inside.
I used to have a link to a video of this process, but can't seem to find it right now.
-Richie,
2Spoons
Thu Jul 26 2012, 10:20PM
I'm aware of the usual methods of making thermocouples, unfortunately a spot welder is not among our workshop arsenal. Yet.
And as for this guy ...
Dri0m wrote ...
well, sorry, but i have to:
What? Pour scorn on a post outlining a simple solution to a not so simple problem that just might help out another 4HV member?
Harry
Thu Jul 26 2012, 11:34PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
I agree, I think it is a good solution to a challenging problem.
I'm sure a lot of people on this forum are annoyed when the electrodes melt cheesey
What two metals did you use?
2Spoons
Fri Jul 27 2012, 12:07AM
Photo of the result, next to a 1mm scale. A bit oxidised but works fine. An inert gas shield would help - but didn't have anything available.
Type K thermocouples are chromel {90% nickel and 10% chromium} and alumel {95% nickel, 2% manganese, 2% aluminium and 1% silicon}. The thermocouple wire I was using has teflon insulation, which is a PITA to strip. The other arc electrode was a 3mm dia steel rod, sharpened to a point.
1343347497 2939 FT142298 Thermoc
GeordieBoy
Fri Jul 27 2012, 01:35PM
...be sure to check out the video at the bottom of the page too,
-Richie,
