  • Guests: 44
Elliott (35)
Gratitude (40)
Swraka (37)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
TeslaCoil grounding
Unleashed
Tue Jul 24 2012, 09:33PM Print
Unleashed Registered Member #5171 Joined: Tue Jun 05 2012, 11:32AM
Hello everyone.
In these days, i'm making the tests of my first TC.
That's the situation.
My home is 3 floors.
I live on the 3rd floor, but for the tests i have every time to go at the ground floor, carry all the stuffs and that's very uncomfort for me.
So, i was wondering.
1) can i ground the secondary on the mains ground? (if yes, how can i test if the ground is ok?)
2) Since my dedicated grounding rod is at the ground floor, can i run a cable from my floor to it? Would the high inductance of a that long cable change something?
Thanks.
Sigurthr
Tue Jul 24 2012, 10:11PM
Do not use mains ground. Ever.
You can run a cable to the ground rod, just use very thick cable so the inductance is kept low. Welding cable is ideal, and old stuff that is burned/singed but electrically good can be bought for cheap at welding shops since no welder wants to use a cable which has lost it's insulation.
Unleashed
Tue Jul 24 2012, 10:13PM
Since i have my reel of 0.25mm enammeled wire i used for the secondary...
Can i use it?
Sigurthr
Tue Jul 24 2012, 10:20PM
No, that will not work well at all and would be dangerous. The ground line on a TC caries high RF currents but low voltage, you cannot use thin single conductors. Stranded wire is almost always preferred (single conductors act as hollow tubes and most of the conductor is invisible to the current).
The thinner the wire, the more impedance it has. The entire reason you don't use mains ground is that it is HIGH impedance to tesla coil frequencies... and your coil will blow up anything electronic in your house... and in any other dwelling connected to yours through a common junction box.
I have used 14AWG in a pinch, but I would not use anything thinner than 10AWG for a permanent installation.
Dr. ISOTOP
Tue Jul 24 2012, 10:30PM
Sigurthr wrote ...
I've run coils grounded to mains ground without any ill effect, so this is not necessarily true. It matters more for SGTC's I think.
And stranded and solid wire have the same AC resistance; you need Litz wire (which is braided) to lower the AC resistance.
Unleashed
Tue Jul 24 2012, 10:31PM
Thanks both of you.
So, i can use the mains ground?
Will i need any kind of filter capacitor?
Another thing is.. How can i test if i have the mains ground? (central pin)
Thanks.
Wed Jul 25 2012, 12:03AM
How large is your coil? Is it solid state or spark gap?
Unleashed
Wed Jul 25 2012, 12:07AM
Small SSTC, built following this guide Link2
Here: Link2 is also a photo.
The specs are
10cm secondary diameter, 1000windings
8cm diameter topload, 25cm large diameter.
Wed Jul 25 2012, 03:00AM
Living on 7th floor of a building, I have the same problem.
I started a thread about this a year ago, where you might find some useful answers Link2
So far, I ran a VTTC (non disruptive coil) Link2 on mains ground without problems.
Sigurthr
Wed Jul 25 2012, 06:44AM
Dr. ISOTOP wrote ...
Correct, but I was thinking more of the mechanical aspects of bringing heavy gauge wire up several floors in height, not the electrical. I was a welder for 5 years and often had to work up high with long cables; finely stranded/braided cable is much easier to work with than solidcore. Sorry for the confusion, my statement that stranded is often preferred was a bit vague.
