  • Guests: 36
Elliott (35)
Gratitude (40)
Swraka (37)
12/29 Cprossu (40)
12/29 Kokamo (46)
12/29 GalliumMan (60)
3 pin hard drive motor
alf
Sun Jul 01 2012, 10:04AM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hi,
i have this hdd hub motor, it has 3 pins, any idea of the pinout?
its not a dc motor, cuz when i connect it to a battery directly it just jerks and then stops as i expected...
i thought that if its a 3 phase motor it would need 4 pins, common and each end of the star configuration
(the chassis of the motor is not another pin btw)
thanks in advance, alf
Avalanche
Sun Jul 01 2012, 10:50AM
It'll be a three-phase motor - if it were delta wound there would be no neutral connection, and if it were star wound there would be no need to connect he star/neutral anyway as it's a balanced load (also on a simple 6 switch inverter, there's nowhere to connect the neutral anyway).
You can build a simple little inverter using 3 gate drive ICs instead of fiddling around with individual transistors.
radiotech
Sun Jul 01 2012, 11:51PM
If it is a 3 phase AC motor, you could try connecting a capacitor, (10 uFd)
between any two wires. Then connect AC, from your Variac, across the free
wire, and one of the two going to the capacitor.
If it rotates, then try the AC to the other leg going to the capacitor. This
may reverse rotation.
1341186660 2463 FT140986 Motor Forwaqrd Reverse
hsieh
Mon Jul 02 2012, 12:35AM
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
You can use ESC for remote control car/aircraft.
I tried it before and make a small Grinding machine using an old HDD.
brandon3055
Mon Jul 02 2012, 05:30AM
I'm curious dose enyone know how to build an ESC for a brushless motor (or have a basic circuit to build off of)
Mon Jul 02 2012, 05:41AM
Destroyer of mosfets wrote ...
stepper motor circuits are out there... and IC's too. but they can get kind of complicated for 3 phase stuff, since you need sensor feedback and or emf feedback, id reccomend getting a 10 to 20 amp ESC from a hobby place. depends your motor and on what you want to do too.
radiotech
Mon Jul 02 2012, 06:03AM
What do you mean by brush less motor and what is ESC ?
Mon Jul 02 2012, 06:12AM
radiotech wrote ...
Electronic Speed Control, ESC.
EDIT: it should be noted that there are many types of brushless motors (i think this is what radiotech is alluding too.) Relecutance, stepper, ac phase, and so on...
Dr. ISOTOP
Mon Jul 02 2012, 06:47AM
See here Link2
alf
Sat Jul 28 2012, 08:27AM
thanks for your replies,
sorry i took to long to reply... heh
it works with single phase AC, but at 50hz, not very fast, i need to get my sig gen working! (damaged with HV arc) :D
