  • Guests: 36
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
how to get 1 megavolt
1 2 3 4  last
Microwatt
Wed Jul 18 2012, 02:43AM Print
Microwatt Registered Member #3282 Joined: Wed Oct 06 2010, 05:01PM
lets talk about ways to obtain 1 million volts dc. can it be produced without a marx? what about dual CCW multipliers? what sort of cool experiments can you do with a million volts?
Daedronus
Wed Jul 18 2012, 09:11AM
Build a huge Marx Generator
Like this Link2
but bigger
Dr. ISOTOP
Wed Jul 18 2012, 03:39PM
Microwatt wrote ...
wow no replies??
Give the forum some time...6 hours isn't much!
On topic, it is very hard to reach a megavolt. Sources like multiplier stacks don't really like sourcing any current, and even if you had infinitely large capacitors and diodes you would have to do some serious engineering to eliminate corona (or use sheer brute force to overcome corona losses).
You'd be looking at hundreds of dollars of diodes, thousands of dollars of potting epoxy, and a large number of capacitors.
Forty
Wed Jul 18 2012, 04:29PM
"A million volts o' fun"
strangely enough, I already had this page open on one of my browser tabs. A marx is probably the cheaper way to go
GluD
Wed Jul 18 2012, 07:14PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
A large Van de Graaff generator could do it too.
The following is taken from wikipedia:
The potential difference achieved in modern Van de Graaff generators can reach 5 megavolts.
The largest air-insulated Van de Graaff generator in the world, built by Dr. Van de Graaff in the 1930s, is now on permanent display at Boston's Museum of Science. With two conjoined 4.5 meter (15 foot) aluminium spheres standing on columns 22 feet (6.7 m) tall, this generator can often reach 2 MV (2 million volts).
Thus I would add the Van de Graaff generator to the list of 'suspects'.
I assume the 5 MV generator is insulated with sulfur hexaflouride, which should be do-able for a serious hobbyist.
technology man
Wed Jul 18 2012, 08:57PM
technology man Registered Member #4193 Joined: Mon Nov 07 2011, 11:21AM
use lightningstrikes !
Wed Jul 18 2012, 10:37PM
i sware air-cored transformers/ teslacoils can create such voltages, and far beyond that...
Microwatt
Thu Jul 19 2012, 02:45PM
Is it possible to run a aircore in flyback mode?
Daedronus
Thu Jul 19 2012, 03:44PM
possible? yes, any transformer can be run in flyback mode.
would you want to do that? I don't think so
Microwatt
Thu Jul 19 2012, 11:28PM
Becuase it is easier to get voltage out than power. what engineering limitations are there to a CCW stack besides insulation?
1 2 3 4  last
