  • Guests: 48
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Waveguides
Linas
Sun Jun 24 2012, 08:37AM Print
I have a task for calculating amplitudes in wave-guide, with triangle dialectic target inside.
Any one know how to do this ?
1340527012 1143 FT0 Sort Of
m0 n0 wave come from -Z (-inf) and hit that triangle inside waveguide
1340526923 1143 FT0 52
Here i have all projections for EM waves and all modes
WaveRider
Fri Jul 06 2012, 10:36AM
This is not a trivial problem. If you have an incident TE10 wave (E is y-directed), then transmitted and reflected waves must be TEm0 type. This simplifies the analysis. However, the method I describe will work for any mode type. You can approximate the triangular dielectric interface as a stair-stepped interface. You find the pertinent modes of the dielectric loaded waveguide and represent every "step" as a short piece of waveguide where we "match modes" at the ports between one section and the next. This is done by enforcing continuity on the tangential (to the waveguide ports) E and H fields. This will require the computations of lots of inner-product integrals and the numerical solution of the resulting linear system of equations. It is VERY IMPORTANT to include evanescent modes in the analysis, otherwise the results will be wrong. Google "electromagnetic mode matching technique"..
