  • Guests: 31
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
brick speed
Ben Solon
Sat Jun 23 2012, 05:16PM Print
i have never used a brick before, and i might use on or two for my new ih. how can i know how fast can i switch them zcs or zvs? the brick i would use would be the MG200Q2YS40 from toshiba. its not something that i would put my money on for a drsstc switching 600+ amps, but for a lclr induction heater never switching more than a few tens of amps it should bull through with minimal heating. using the (rise+fall+tondelay+toffdelay)*10 rule, the max frequency is ~58khz, and i need to switch at 60khz resonance, and higher to detune.
Sat Jun 23 2012, 07:00PM
With resonant swtiching the IGBTs will take (much) more frequency, your IGBTs will run perfectly fine at 60 kHz with ZCS.
