  • Guests: 69
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Cheapest place to get fiber optics?
Fri Jun 15 2012, 01:15PM Print
hey, im trying to get some fiber optics,
8 sets of:
-sender
-reciever
-1ft of cable between them
just has to send pulses at about... 25 - 175Khz max
somthing simple to set up?
any ideas?
Ben Solon
Fri Jun 15 2012, 01:26PM
I havn't seen anything much cheaper than Industrial Fiberoptics products. they don't use a connector, just clamp onto the end of a bare cable of the right size.
if you get these, you are looking at around 30$:
Link2,fff8042b,fffc006b&chp=0
Link2,fff8042d,fffc006b&chp=0
Fri Jun 15 2012, 01:52PM
how does one cut fiberoptic?
Ben Solon
Fri Jun 15 2012, 02:05PM
there's a tool for it, but its pretty much just a razor in a press jig so that you get a 90deg cut. you may also want to polish the end, but for short distances like 1ft, you probably don't need it.
Fri Jun 15 2012, 02:13PM
ok ^^
another quick question for the same topic,
what is the program people use to make epic looking schematics like this:
Josh Campbell
Fri Jun 15 2012, 03:10PM
Josh Campbell Registered Member #5258 Joined: Sun Jun 10 2012, 10:15PM
There are more "epic" software packages but here are a few:
CadSoft
ExpressPCB
gplEDA
Target 3001
The Epic:
Altium
There are many more!
Ben Solon
Fri Jun 15 2012, 03:12PM
I think it may be express pcb. I use it for bridges of inverters, power boards, etc., but eagle is so much better for complicated circuits.
Pinky's Brain
Fri Jun 15 2012, 04:04PM
You can also use toslink :
Fri Jun 15 2012, 04:51PM
wow, thats really cheap! thanks Pinky!
if anyone can beat that for pricing, id be suppised!
Pinky's Brain
Fri Jun 15 2012, 06:41PM
The only things which are kinda hard to get are short toslink cables (not a problem if you don't mind having some loops tied together with a tiewrap of course). Can't just slice a toslink cable to make it shorter (although if you don't mind bodging it a bit you can probably make something work).
