  • Guests: 31
3kV AC power supply
Unleashed
Sun Jun 10 2012, 03:08PM Print
Unleashed Registered Member #5171 Joined: Tue Jun 05 2012, 11:32AM
Hello everyone.
Just as the title, i wan't to build a 3kV adjustable power supply, but i can't find anything around that may help understanding how to do it.
I don't need any high current, simplest and cheapest as possible.
I would like to have some DIY tutorial, diagrams and more.
Thank you in advance.
Sun Jun 10 2012, 03:10PM
an old transformer off ebay or 2 MOTs + a variac?
Unleashed
Sun Jun 10 2012, 03:11PM
Sorry for my unexperience, but what is a variac?
Sigurthr
Sun Jun 10 2012, 03:48PM
A variac is a variable transformer that lets you adjust how much voltage comes out of the wall and in to the device you plug into the variac.
2 MOTs and a variac are your best bet for high current, but variacs are not cheap.
Unleashed
Sun Jun 10 2012, 03:51PM
Yeah, i saw some on ebay.
And what voltages would me allow to reach this config?
Newton Brawn
Tue Jun 12 2012, 02:01AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Yes !
You may use a light dimmer, 120V, 500W and Microwave Ovem Transformer .
The MOT receives 120V and transform to 2200V . Remember that one secondary HV lead is connected by the manufacturer to the transformer core.
The primary is to be connected in series with the dimmer.
The mot you can find easyly in the street or in the Enviromental Day Party. No cost.
And inside the mot a lot of usefull components to do HV. !
The dimeer is$$ 5.99 +tax
It is appropriate to put a 4 amp fuse, 20mm of copper wire # 27 (0.36mm diameter) can perform the 4 A protrection with perfection
Regards !
Newton
Edit : the 2200V refer to RMS voltage, or 3100 volts of peak. Using the microwave capacitors and microwave rectifiers you may double this voltage (6200V)
Unleashed
Tue Jun 12 2012, 10:47AM
wow that's fantastic, thanks a lot.
I think i'm gonna go around looking for some microwave oven.
I've been looking for infos around and having a mot would be fantastic.
I'll let you know when i find one.
Thanks
brandon3055
Tue Jun 12 2012, 11:06AM
Newton Brawn wrote ...
Newton
Thats DC don't you need AC and what will you be using it for?
Unleashed
Tue Jun 12 2012, 11:30AM
I think it will be ok AC 2200volt dimmerable, it's already a good voltage.
What i'm going to do?
Actually i don't know, but it's nice to have a high voltage AC out.
I can always correct it with a diode bridge.
Tue Jun 12 2012, 01:11PM
Remember that when using the dimmer, the output voltage will no longer be a sine wave. The peak voltage will stay for the most part, so eg. the rectified voltage wont change much and then quickly as you regulate towards zero.
