  • Guests: 47
Royer ZVS
Unleashed
Sat Jun 09 2012, 03:02PM Print
Unleashed Registered Member #5171 Joined: Tue Jun 05 2012, 11:32AM
I wrote the same thing on the projects section, but i don't think it's the right one in fact, i didn't receive many answers.
Yesterday, when trying it for the first time i had some problem.
The risonance capacitor, after a while starts running very hot, enough hot to lose is form and start swelling.
Since i can't set any kind of dissipator on the capacitor, what can i do for lowering his temperature while running?
Another problem is also the flyback tranformator, in fact, when it started running (5+5), the windings (normal 1mm wire), has literally liquefied
and again, i would also like to know some furter use of the zvs driver, because until now, i've only heated up nails and tried some spark with the flyback.
My supply is gave by my homemade 15A 1.5-39V Psu
ZVS spechs
MOSFETS : IRFP 250
CAPACITOR: 0.82 uF 400V
INDUCTANCE; about 95 uH
A photo is available here:
Anyway, after some tests, I have noticed that the absorb has increased from 10-12A to overo 20...
Why that?
The flyback, still emits some spark, but it's very thin and short, while the induction heater doesn't even work anymore.
What could be the problem?
thanks in advance.
brandon3055
Sat Jun 09 2012, 03:13PM
If you put a thread in the wrong place just go to the admin thread and ask them to move it
ZakWolf
Mon Jun 11 2012, 01:24AM
make an mmc for the resonance cap section.
also it has to be a good quality cap
Unleashed
Mon Jun 11 2012, 07:42PM
Hello
thanks for answer, so far i'm making some test with different types of capacitors.
I've noticed that yesterday, with
a combo of
400volts 1,5uF
2x250volts 2.2uF i had the best result and the lowest amp drain.
Now i made some test with an array of 7 400volts 0.56 uF, i had some arc, but it's not like yesterday, and the amps drain is much higher (like 16 instead of 9-10).
Then i have tried with a giant 33uF mkt capacitor, and the amp drain is very much higher(over 20), and no arcs.
I'm still trying to understand the ness between capacitance and drained amps.
But.. I don't get it.
Can somebody help me realizing how it works?
Thanks.
Mon Jun 11 2012, 08:13PM
I believe the secondary of the flyback has a resonant frequency, and you get the best results when you tune the primary to this same frequency.
Unleashed
Mon Jun 11 2012, 08:23PM
So the best way of doing it it's making tries?
Anyway, how many windings should i make on the primary?
5+5 or 4+4?
ZakWolf
Tue Jun 12 2012, 06:51AM
Unleashed wrote ...
5+5 or 4+4?
Im no expert... but its my understanding that with a lower turn winding such as 3+3 you will have bigger arcs but it will cause harder switching and more heating to a degree. ie: you wouldn't notice the difference running it with 12v with 3+3 or 5+5 as far as heating goes, but i think it plays a bigger role in higher volts and amps.
Some one please correct me if im wrong
hope this helps,
ZakWolf
double post ._.
Marko
Tue Jun 12 2012, 06:25PM
Hello -
My biggest suspicion is simply that your flyback is dead, and that's why it is pulling huge current and giving wimpy arcs. There is no way this circuit should pull 15A at 40V with no load, something is doomed to blow up very quickly that way.
For the induction heater, see Link2
Unleashed
Tue Jun 12 2012, 07:27PM
Thanks for the answer.
The fact is, that i've tried another flyback and this time i get always ultra absorb, and this time not even a little arc.
Maybe this one is fucked up as well, i can't know because it's from a old tv that i found in the street.
Anyway, i will try with some other flyback when i find one.
Thanks.
