  • Guests: 37
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
IGBT ZVS FOR higher voltage?
Dri0m
Thu Jun 07 2012, 03:52PM Print
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
hello,
do i need some modifications for running ZVS with IGBTs, powered by 60-80V (i will rewind my MOT), and on high frequency (1MHz) ?
This IGBTs look OK , and they are quite cheap ($3) and fast enough to do the job.
probably more powerful zeners on higher voltage, better cap, but should i change resistors or choke coil?
Thu Jun 07 2012, 04:02PM
There is possibly no way you can get this circuit running at 1 MHz, even more so with IGBTs.
Dri0m
Thu Jun 07 2012, 04:12PM
i ran my ZVS induction heater on 7MHz with IRFP250N...
1MHz will be used for powering tesla coil (why not hm? :D )and other air-core stuff, DSTs will run on lower f...
Thu Jun 07 2012, 06:47PM
if i am correct, the FETs in the inductionheater didnt acctualy go at 7MHZ, they caused a "ringing?" between L and C that is 7 Mhz
im probibly wrong tho ^^
Thu Jun 07 2012, 09:52PM
Maybe he measured the frequency with a multimeter, which "counted" the ringing too.
