  • Guests: 36
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Will a mot work for a audio output transformer?
Luceš
Thu Jun 07 2012, 01:35AM Print
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
Hi! I am building a low budget hillbilly amp... And output transformers are the weightless plan for my wallet. Anyone know if a mot will work in a pinch? Ps I'm using an 833a
Thu Jun 07 2012, 06:59AM
I've seen a single ended amp made with an 833 and a MOT before. smile I think it was done by "Experimentonomen", he is on the forum and sometimes in the 4hv chat.
Thu Jun 07 2012, 09:24AM
If you put an air gap in it, it could work somewhat... No bass, no treble, but with an 833 it will scream enough tongue
Ps. You might need to rewind the secondary (the original primary) with fewer turns. Remove the shunts to decrease leakage.
Ps2: If it is a 120V MOT, the original primary may have around the right number of turns.
Luceš
Thu Jun 07 2012, 12:31PM
I think will have to modify the secondary so there are about 40 turns.
Thanks guys
