  • Guests: 37
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Wireing my Variac
Sat Jun 02 2012, 08:32PM Print
hows the best way to wire it guys?
also, anyone know a good soft start circuit for a 28A (could probibly take 35A)
Mbs5Hs
Sat Jun 02 2012, 10:34PM
mister_rf Registered Member #4465 Joined: Wed Apr 18 2012, 08:37AM
This coil may be used used to step up or down between voltages in the 110 -120 volt range and voltages in the 220-230-240 volt range, e.g., to output either 110 or 120V (with taps) from 220/230V input.
A-C = 120Vac
B-C = 110Vac
A-E = 240Vac
A-D = 230Vac
B-D = 220Vac
To be connected as a variac we chose one end of the winding to be connected in common to both the voltage source and the load and secondary connection through the sliding brush, giving a variable turns ratio.
Ben Solon
Sat Jun 02 2012, 11:06PM
Is it a variac or just a multiple tap auto transformer? And did you wind that yourself? Looks nice.
Sat Jun 02 2012, 11:16PM
ben123324 wrote ...
its a 1980~'s variac, im renovating,
im thinking:
in:
A-Ground
D-Live
out:
A-Ground
Brush-Live
for some overturn voltage?
Ben Solon
Sun Jun 03 2012, 12:41AM
If you live in the us, it's nice to have some extra voltage, but on a 220-240v circuit, I can't think of very many situations you would need an extra 20-40v. Except maybe to push an sstc or drsstc to its limits.
Sun Jun 03 2012, 01:13AM
or just entertainment ^^
so that'l work guys?
Ben Solon
Sun Jun 03 2012, 03:26AM
should. an the case you use one extra tap, you will get less stress on the transformer. one less, and more stress. but these thing are tough. i use a small power supply xfmr as an autotransformer, and it doesnt mind at all having a couple amps at 240v running through it. and with open winding, yours will handle much much more. have fun.
Alex M
Sun Jun 03 2012, 04:02AM
A: Neutral (this is also common to your variacs output).
D: Live
With A as neutral and D as live E will probably give around 270v.
Sun Jun 03 2012, 07:32AM
Tom Williamson wrote ...
If you don't trust my calculations, count the number of turns.
AD= ~233
AE= ~269
cheesey
Sun Jun 03 2012, 10:01AM
hehe, thanks, now, whats the best way to setup somthing to stop the inrush current?
