HV protection circuitry and common design guidelines
rp181
Thu May 31 2012, 06:47PM
Registered Member #1062
I will be designing a multichannel power amplifier soon. I will be using PA78 HV Op-Amps (Digikey) with this power supply.. This module outputs 380V, but my output should never exceed ~200V (Can anyone find a similar module with this output?) The output voltage will be controlled with a 16 bit DAC. I plan on limiting the gain of the Op-Amp to prevent the voltage from going too high, but what are some ways I can ensure the output on each channel never goes past a set voltage? I need to protect the output at all costs- I would much rather build a new driver than damage the piezoelectric system it will be driving. What are some ways I can do this, and what are some common guidelines for designing circuits like these?
Registered Member #162
The simplest is to put a suitable (string) of zener or tvs diodes from the output to the inverting input. The diodes will have capacitance which must be accounted for in the feedback design.
