  • Guests: 56
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Best circuit for getting 300ish VDC from 120VAC (wall outlet)?
Yanom
Thu May 31 2012, 04:43PM Print
Yanom Registered Member #4659 Joined: Sun Apr 29 2012, 06:14PM
So I need a way to get about 300 volts DC from a wall outlet plug. I've looked at circuits for villard cascade/cockcroft-walton generator type circuits, or I could also get a transformer and step up the wall plug AC to 240-360 volt range, then rectify that current. What's the best circuitry for this?
Ash Small
Thu May 31 2012, 04:58PM
transformer plus rectifier will probably charge the caps faster than the cockroft-walton multiplier, but the multiplier 'may' cost less, depending on what caps you get, etc.
Yanom
Thu May 31 2012, 06:02PM
Ash Small wrote ...
What are the requirements for the caps? all the diagrams of CW multipliers I see don't have any labels on the capacitors. Obviously I need a voltage rating of 300V or more, but what should the capacitance be?
Marko
Thu May 31 2012, 06:54PM
Hello,
As you only need a doubler, I'd start by looking for two biggest motor run capacitors you can find. They are common in junk like washing machines and usually about 20uF in europe - I assume they're about 40uF in US then.
Charging time depends on size of your bank too, if your bank is small then it might charge too fast for you to shut it off manually before it reaches over 300V in which case you might want to use smaller doubler caps (any will work as long as they are nonpolarized and rated for adequate voltage).
Marko
Saz43
Thu May 31 2012, 07:17PM
Yanom wrote ...
You can use any capacitance in the voltage multpilier, but higher capacitance means more current, and a faster charging time. Here's a calculator that will show you the relationships involved. The best way to design this though is to get LTSpice (free) and design your whole circuit. Or if you want you can give me your specs and I'll run a sim for you.
Yanom
Thu May 31 2012, 09:35PM
Marko wrote ...
Is that bad?
brandon3055
Thu May 31 2012, 09:46PM
I did not now the caps had to be non polarized I was able to build a very successful dubler using camera caps to charge my 450v bank from from 240v but maby that's why my charge resistor got so hot
Yanom
Fri Jun 01 2012, 05:21PM
Destroyer of mosfets wrote ...
Can anyone tell me why the caps have to be non-polar?
Also, do all the caps have to be the exact same?
Pinkamena
Fri Jun 01 2012, 11:37PM
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
Yanom wrote ...
Marko wrote ...
Is that bad?
Well, you do not want to charge your caps above the rated voltage, as it will damage them.
Sat Jun 02 2012, 10:43AM
I would rather use an isolating transformer with bridge rectifier than a doubler
because the 300V circuit will be isolated from the ac line
- safer
- able to connect oscilloscope etc.
